Big tires and front sprocket cover...
  • racer54
  • racer54's Avatar Topic Author
06 May 2012 16:52
#520244
Curious about what you guys who have mounted a 180+ tire out back and used the stock counter-shaft sprocket cover. Did you have to modify the inside of the cover? Did you space it out any? Any pics. you can share? Did you use a 5/8" or 1/2" offset sprocket? Did you do anything to the rear wheel...modify the hub on a sportbike wheel or offset lace a wire wheel to move it to the right for clearance?
  • MFolks
  • MFolks's Avatar
Re: Big tires and front sprocket cover...
06 May 2012 17:48
#520259
Ask at these websites, tell them your plans, and they should advise you.
Sprockets And Drive Chains
www.sprocketspecialists.com/ (not sure if they are still in business)
www.sunstar-mc.com/home.aspx
www.rebelgears.com/
www.pmpsprockets.com/
www.schnitzracing.com
www.jtsprockets.com
www.pmfronline.com/counter_shaft_sprockets.php
www.dgchassis.net/
  • MFolks
  • MFolks's Avatar
06 May 2012 17:51
#520260
If you need to change sprocket sizes, use this website: www.gearingcommander.com
  • z1kzonly
  • z1kzonly's Avatar
06 May 2012 18:33
#520269
racer54 wrote: Curious about what you guys who have mounted a 180+ tire out back and used the stock counter-shaft sprocket cover. Did you have to modify the inside of the cover? Did you space it out any? Any pics. you can share? Did you use a 5/8" or 1/2" offset sprocket? Did you do anything to the rear wheel...modify the hub on a sportbike wheel or offset lace a wire wheel to move it to the right for clearance?
Good question R 54! I was thinking that also. I had that 77KZ1000 project I sold to a friend
I gave him a flat 5/8" offset 530 size sprocket and an extra cover to mock it up with.
You can only grind about 3/16" off. I would say some collar spacers and longer bolts.
Then you got to get into a longer clutch pushrod. Which the tips are hardened steel.
Probally need some drill rod.
Sure hope someone chimes in and with pictures.
  • racer54
06 May 2012 18:36
#520272
Never thought about having to lengthen the clutch push-rod. I've seen where someone had to cut quite a bit off the back of the c/s cover so chain would clear but have seen a few where it didn't look like the cover was moved out or cut so that's why I was curious about how they did that.
  • Reichmanner
  • Reichmanner's Avatar
06 May 2012 21:52
#520334
Read through this build thread
www.kzrider.com/forum/11-projects/451145...-bastard-kz650-build
and he is running a 190 rear tire. Good pics too
1981 kz750 ltd (Project BOB)
1982 kz750 Spectra (Project Street Fighter)
  • ramtough_63
  • ramtough_63's Avatar
06 May 2012 22:08 - 06 May 2012 22:08
#520345
with my 190 and 1/2" offset My 520 hit the counter sprocket cover ever so slightly just grabbed the die grinder and releave it about 1/2" where I saw the marks (from the chain rubbing)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Last edit: 06 May 2012 22:08 by ramtough_63.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
06 May 2012 22:22
#520358
I'm running 530 chain with about 9/16 offset sprocket, I had to cut out the back of the cover and cut the lip off around the back. I'm going to be in to it later in the week changing speed sensor so I'll post some pics of the modifications if needed. I also had to take a little off the rear sprocket carrier but don't remember the exact amount.
Les
  • JEFFG1
  • JEFFG1's Avatar
07 May 2012 11:04 - 07 May 2012 20:00
#520463
i have a 200 on my orange bike -- used a 5/8th offset on it that is 530 pitch - gsxr rear wheel that is close to 6" wide.none o ring chain the o ring chain is wider so you dont want to use one of them.you will need to notch the frame or heat it and flatten it where the chain rubs you will see where as you build this . also you will need to grind some of the inside of the cover.i put 2 little washers on all the bolts to space it out close to 1/8". when you look at the bike it looks stock. i had no problem with the clutch rod ?? i have a wide swingarm also so you have room to move around but my wheel is in the center no offset. i will take some pics when i get home. very easy to do.
Attachment MYBIKE283.jpg not found
Attachment MYBIKE284.jpg not found
Attachment MYBIKE285.jpg not found
Attachment MYBIKE287.jpg not found
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
Last edit: 07 May 2012 20:00 by JEFFG1. Reason: ADD PHOTOS
  • JEFFG1
  • JEFFG1's Avatar
07 May 2012 20:09
#520558
THIS ONE HAS A 190 WITH THE SAME SETUP
  • JEFFG1
  • JEFFG1's Avatar
07 May 2012 20:12
#520559
THIS IS MY OTHER BIKE IT HAS A 190 WITH THE SAME SETUP
Attachment DRAGBIKE245.jpg not found
  • racer54
07 May 2012 23:43
#520620
Somewhere I seen where a guy spaced his cover out but a little more then 1/8th inch and made a spacer that followed the shape of the cover itself. Looked trick but bet he had a lot of time in that one little piece. Filled in along the whole top edge of the cover. Was there much difference in clearance between the 190 and 200 tire? I have a 190 but was thinking of getting the 180 for a little more clearance...not sure if it would be an issue though.
