HELP JUST BROKE.....
30 Apr 2012 18:03 - 30 Apr 2012 18:04 #518854 by jdbusch
HELP JUST BROKE..... was created by jdbusch
ok so i was trying to remove my rear shocks and the acorn nut just twisted the stud apart.
havent removed shock yet how (once i pop the shock off) do i get that upper shock stud outta the frame?
is it threaded? Welded? all i can see is that it dosent go all the way through the frame.
can i use a regular grade 8 bolt?
damn i cant win!
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
Last edit: 30 Apr 2012 18:04 by jdbusch.
30 Apr 2012 18:11 #518855 by MFolks
Replied by MFolks on topic HELP JUST BROKE.....
I believe the stud is welded to the frame. I'd think if you can get a drill in this tight space & drill out the weld, a new bolt could be welded in to replace it. If it were me, I'd be using a Cobalt drill bit, as the weld might be difficult to drill out.
You might have to drill from the outside due to space restrictions. If possible. use a grinder to make the place to be drilled as flat as possible, otherwise the drill bit may go off center.
Take a good center punch & hammer to make a dimple so the bit won't wander, and use some cutting oil to keep the bit cool.
The following user(s) said Thank You: jdbusch
30 Apr 2012 18:27 #518860 by jdbusch
Replied by jdbusch on topic HELP JUST BROKE.....
the thought of kicking it over and roasting marshmallows on it while i dance naked around it is really beginning to appeal to me.
but as i am trying to keep my composure and sanity. i think i will call a few shops around here and see if what they will charge to fix the stud issue.
thanx MFloks
Current:
Gone:
Email:
30 Apr 2012 18:38 #518861 by MFolks
Most "Broke" things can be repaired. It might take $$$$ for some situations, but I don't see your problem as being unfixable. Next time, use "Kroil" or "PB Blaster" on stuck fasteners....
30 Apr 2012 19:31 #518874 by 650ed
Replied by 650ed on topic HELP JUST BROKE.....
MFolks wrote: Most "Broke" things can be repaired. It might take $$$$ for some situations, but I don't see your problem as being unfixable. Next time, use "Kroil" or "PB Blaster" on stuck fasteners....
+1
30 Apr 2012 20:17 - 30 Apr 2012 20:21 #518886 by jdbusch
pb'ed the hell outta it lol
and as luck would have it. the shocks a buddy of mine was gonna let me use till i could get some the eyelet is smaller than the stud. hehe :blink: *twitch, eye roll, :silly: twitch, jerk* :S heehee
so i guess.
Current:
Gone:
Email:
Last edit: 30 Apr 2012 20:21 by jdbusch.
30 Apr 2012 20:58 #518891 by MFolks
Depending on the eyelet size,most bushings can be pressed out with a bench vice & small socket, but now you may have a problem, as the rubber will wear with no bushing.
30 Apr 2012 21:05 - 30 Apr 2012 21:06 #518893 by jdbusch
ok now that i have vented and relaxed does anyone know a way to get the stud out?.. it looks as though it slips into a sleeve welded to the frame. is it pressed, welded, or just rusted?
Current:
Gone:
Email:
Last edit: 30 Apr 2012 21:06 by jdbusch.
30 Apr 2012 21:08 #518895 by zed1015
Replied by zed1015 on topic HELP JUST BROKE.....
Is this on a z9/1000 ?.
That shock mount is welded on solid and not a simple job to remove as it is welded front and back.
The common fix is to level the surface where the threaded portion sheared off and carefully drill up the center and tap M8 to take a bolt.
The bolt is only there to stop the shock from sliding off the mount and the mount will be just as strong as before.
30 Apr 2012 21:15 #518898 by zed1015
jdbusch wrote: ok now that i have vented and relaxed does anyone know a way to get the stud out?.. it looks as though it slips into a sleeve welded to the frame. is it pressed, welded, or just rusted?
On the z9/1000 etc that mount is all one piece, not a threaded sleeve with a stud in.
30 Apr 2012 21:16 #518899 by ramtough_63
Replied by ramtough_63 on topic HELP JUST BROKE.....
zed1015 wrote: Is this on a z9/1000 ?.
JD this is the route I would take. I am pretty sure you could do it without it being a complete nightmare
switch out the bushing on the shocks thats what i did when i put the other shocks on mine. the kz bushing was larger than the shocks i used
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
30 Apr 2012 21:45 #518903 by jdbusch
the eye is also alot wider. just realized that when i was looking. and i still have to change out the original stud cuz i broke off the threads. ive got a set of KAWI irhocks coming i was just impatient. but at least it broke before the parts came in so now i have a chance to fix it and have it ready to go instead of a temp job then doing it again lol
Current:
Gone:
Email:
