Droppping the Forks?
- badrhino
25 Apr 2012 12:34
I have a 1980 KZ1000 and was wondering what is an acceptable distance to lower the forks in the tree? I know I have read it somewhere before but can not find it now.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- Kidkawie
- I bleed premix
Re: Droppping the Forks?
25 Apr 2012 14:15
Lower the forks in the tree? I wouldn't go any lower than having the tops of the fork tubes flush with the top of the clamp.
If you mean lower the trees, essentially raising the fork tubes, about 10-12mm is a decent usable range.
If you raise the forks too much the bike will become unstable at higher speeds.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- mark1122
- Keep twisting it
25 Apr 2012 18:08
X2
but i would be woried about stability unless u r planning some high speed stuff. i'd be more worried about hitting the header on a road speed bump if u dropped them too far.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- badrhino
26 Apr 2012 01:51
Yes I meant raising the forks for different stance and quicker handling.
Franken Z!
Franken Z!
- damarble
26 Apr 2012 02:00
Mine's a 750 so it's not exactly the same, but I raised them about 2" to get the clip ons on. Haven't had it faster than 70 but I haven't noticed any instability, rides great.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- Kidkawie
- I bleed premix
26 Apr 2012 10:36
Sometimes major changes have negative affects. If you're lowering the rear it will balance out.
Only a 2-5mm change in, what's actually called "fork height", can make a huge difference in handling.
1975 Z1 900
2004 KX125
2004 KX125
