kz750 g front caliper slides
  • xbmxxx
  • xbmxxx's Avatar Topic Author
24 Apr 2012 23:04
#517910
Does anyone know a source for these? I need 1 slide as well as 1 of the rubber boots that goes over it. I couldn't find any on z1, and google isn't any help either.
76 KZ750B Twin
Re: kz750 g front caliper slides
24 Apr 2012 23:24
#517916
Which pieces in the diagram do you need?
Attachment 000aaa.jpg not found
  • xbmxxx
24 Apr 2012 23:35
#517919
650ed wrote: Which pieces in the diagram do you need?
I THINK 16 and 11.
heres a quick pic
the part thats circled in red.
76 KZ750B Twin
25 Apr 2012 00:03
#517926
I’m a little confused, your title days KZ750 G, but your signature says 1976 KZ750 B. The first diagram I posted is for the 1980 KZ750-G1. Below is a diagram for the 1976-B1 model. The part labeled #11 (part # 43052-005) in the first diagram is still active and is used on both the B and G models. The part labeled #16 (part number 92001-1293) in the first diagram is also still available, but is for the G model and NOT the B model. The parts on the second diagram (below) labeled #18 (part #92007-032) are for the B model but NOT the G model and they also are still available. The good news is that it appears the parts you need are available whether you have a B or G model; just be sure to order the correct ones for your model. Ed
Attachment 000aaa_2012-04-24.jpg not found
  • xbmxxx
25 Apr 2012 01:09
#517938
Sorry for the confusion. I have a 76 KZ750B1 as well as an 80 KZ750G. So I should be able to get them from the dealer? I was hoping for something online as I have a hard time making it to the dealer before they close due to my schedule.
76 KZ750B Twin
  • xbmxxx
25 Apr 2012 01:10
#517940
Also, thanks so much for the help!
76 KZ750B Twin
25 Apr 2012 11:44
#518000
Z1 Enterprises can probably get them for you. Also, Ronayers.com can get them; I have ordered from them several times and was pleased. If you plug the part numbers into the "Search" box at their website you can see the prices. Ed
