17" rear rim for a shaft drive
- 1100fighter
23 Apr 2012 16:19
I have a 1981 kz1100a shaft drive. Did they make a 17" rear rim that will fit my bike? Alot of the sportbike tires I like don't come in 16s. I would like to go to a 17" if possible.
Throttle junkie since 5
Re: 17" rear rim for a shaft drive
23 Apr 2012 16:53
i believe you will have to have one custom altered to work.
i saw a v-max that kosman had taken the hub out of a v-max wheel and installed it into a busa wheel so the guy could have a 200mm wide 17.
- 1100fighter
23 Apr 2012 17:52
I was hoping that maybe a later year had a 17 that would swap. I will probably just have mismatched tires front and rear. Does anyone know if 140/90 16 is the widest rear you can fit on a shafty? I saw a few 150/80 16s
- myelr21
24 Apr 2012 21:14
kz1300 had 17 inch rear shaft they may fit.
07 zx1400 candy blue pc3 dual staintunes.
project z1000j, gpz1100 engine, 1400 big block mtc, kerker with race baffle, 37mm keihin cr specials, gsxr1100 usd front , gsxr 1100 monoshocked rear.
