electrified gas tank!
- lemo32
- The Price of Cool aint cheap
22 Apr 2012 22:14
Anybody used electrolysis to remove tank rust? got my soda ash today, got my battery charger throwing twelve volts at it, saw a few things on the web and decided to try it.
1979 kz 1000 06 katana 750
- gd4now
- Denco where did you go?
Re: electrified gas tank!
22 Apr 2012 23:15
Yes I have done so before. A suggestion I would make is to buy some plastic window screen and wrap it around a couple a lengths of threaded rod. You can bend the rod to the shape you need, push it into the small hard to reach areas in the tank, and the plastic screen will keep it from grounding on the tank,
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- roy-b-boy-b
22 Apr 2012 23:19
If you have a lot of rust this method takes too long. Use a acid rinse. There should be a lot of post on this subject. I have posted before with pictures. Roy
- Hollywoodmx
26 Apr 2012 22:37
I just did this on my bike a few weeks ago. Worked like a charm. I put the bolt though a spray can cap. I left mine running for about 5 days. Poured off the rust every day till there hardly wasnt any.
I then rinsed it well then through in some 2 stoke gas and sloshed it around to coat the tank.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- PFD
27 Apr 2012 01:13
Haven't done the electrolysis method but if you have the time I'd recomend you try soaking it in white vinegar for a week or two. Got my rusty kz1000 tank spotless. I posted pics in a thread about it recently.
78 Kz1000A2, 77 Cb750K daily rider, pinstriper and signpainter
- uneasy_rider
06 May 2012 14:45
Be very careful that the electrode does not get too close to the metal. I........i mean a "friend" burnt a hole through the tank using that method. It works too good sometimes. It did remove the rust......and the metal!
- DaddyJama
06 May 2012 20:55
I used it. Mine was light rust. I used it on a seat pan.. Can't go wrong with a method where u don't have to actually do anything:)
2005 636 - track bike
1982 kz440ltd - new toy;)
- uneasy_rider
06 May 2012 21:21
Trust me, you can go wrong. I have a nice gas tank with a quarter size hole to prove it.
- lemo32
06 May 2012 22:29
I had great results using this method, no more rust, I used an old motorcycle chain wrapped in a rubber mesh, it was the easiest tank clean out I ever did.
