83' Kawasaki Z400 j3
- Sackless
06 Apr 2012 08:20
Hello,
Basically the front brake is spongy and no matter how many time we go through the process of bleeding them we can't get the required pressure, its like an air bubble is trapped somewhere in the system.
Any ideas gentlemen?
PS sorry If this is the wrong section for this question!
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
Ernest Hemingway.
Ernest Hemingway.
- loudhvx
Re: 83' Kawasaki Z400 j3
06 Apr 2012 13:09
That's a rare bike, at least in the U.S.
When I bleed the front brakes, I take the front calipers off and put them on a table near the same height as the master. Then I put a spacer in place of the pads and disk. By bleeding them this way, you don't have to fight gravity and the bubbles don't get trapped. Make sure the bleed nipples on the calipers are pointing up as they would if installed on the bike.
Also, make sure the master gets bled. This means the master cylinder should be near horizontal. Bubbles will appear at the tiny bleed holes inside the reservoir.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Sackless
10 Apr 2012 07:31
Thanks, thats a good idea (and obvious when you mention it)
Would you happen to know any master cylinders (after market/other brand) that would fit? It may be the case I have to replace mine.
Cheers
Cheers
Ernest Hemingway.
Ernest Hemingway.
- loudhvx
10 Apr 2012 13:29
If the J3 has a single disc in the front, then you chouls be able to use one from a KZ550A model. If it has dual discs, then you can use a master from a gpz 550 (KZ550D, H, or ZX550A).
The way to tell is to take it apart and see how bad the pitting is inside the master cylinder.
1981 KZ550 D1 gpz.
Other links.
Other links.
The following user(s) said Thank You: Sackless
- Sackless
12 Apr 2012 08:01
Part ordered, nice one mate!
Ernest Hemingway.
Ernest Hemingway.
