Stupid Tire Question
- Sienar1
01 Jun 2006 11:23
Can tires made for a Mag wheel work on a spoked rim (with tube)? Never had spoked rims - just wondering...:blink:
- OKC_Kent
Re: Stupid Tire Question
01 Jun 2006 12:22
I think not, but it may say on the side of the tire. Some tires need to be used with a tube, and others are designed as tubeless tires.
Cashion, OK
78 KZ650 B2 85,000+ miles
- btchalice
01 Jun 2006 13:29
even the tubeless tires say on the side may require a tube on some wheels
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- billz
01 Jun 2006 14:52
If they are the stock mag type Kawasaki wheels, I'm thinking you'd have needed tubes cause if I remember right they weren't approved for tubeless back then.
Bill
Bill
- Sienar1
02 Jun 2006 08:07
My plan is to build a Cafe Racer out of a KZ750 twin that I picked up off ebay for $150. It has spoked wheels and bad tires... I wanted some more aggressive looking rubber - I like the look of the BRIDGESTONE Spitfires - Tires that require tubes just seem to look... outdated.
- Sienar1
03 Jun 2006 18:18
I called my Kawasaki Dealer and asked them if my idea would work - they said as long as there is a tube, All is good!
- KitNYC
03 Jun 2006 18:52
A couple rules of thumb I've picked up since I got into this bike thing:
Tubeless tires will probably work with tubes, but it's best to check.
Tube tires need tubes.
Spoked wheels always need tubes & rim strips. (There may be an exception or 2 to this, but I'm not aware of any.)
"Mags" are usually okay with tubeless tires, but, again, it's best to check. (The wheels on my 1980 KZ440 worked with tubeless tires.)
That's about it. Bridgestone recommends Spitfire S11s for all the KZ750s listed, so it sounds like they'll work for you.
Cheers,
-Kit
Cheers,
-Kit
- loudhvx
04 Jun 2006 16:22
One exception is on BMW bikes. They have spokes that go to the edge of the rim so they can run tubeless.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
