how do i make cables fit shorter bars?
  • cherokeekid58
  • cherokeekid58's Avatar Topic Author
04 Apr 2012 09:28
#513965
Hi, i am trying to fit a straight drag bar on my stock 82 kz750 but the cables are to long for shorter bars. My bike currently has the 8" "ape hanger" style bars. (Im a noob) anyway how do i shorten the clutch and throttle cables? I already got a new brake lever and resivor off a susuki so its straight and not angled like the old one.
Help please
Cheers
Jason
Hahaha and i thought my JEEP addiction was bad; my Kz addiction is just as bad!!!
www.kzrider.com/filebase/cat_view/102-1982 ,
  • Proxy
  • Proxy's Avatar
  • 80% Human 20% Nuts/Bolts
Re: how do i make cables fit shorter bars?
04 Apr 2012 10:09
#513973
If you got apes then you do not have stock cables on it. Get stock cables and they should be shorter. Also if you have a LTD get standard cables and they will be shorter. Other than that you can have cables made but runs into some $$.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
  • cherokeekid58
04 Apr 2012 10:12
#513975
Sorry it is a ltd
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
04 Apr 2012 10:17
#513977
whack em and solder on ur own ends, there's a You tube video on how to do it
  • martin_csr
  • martin_csr's Avatar
Re: -
04 Apr 2012 14:53 - 21 Feb 2013 15:26
#514034
Last edit: 21 Feb 2013 15:26 by martin_csr.
  • cherokeekid58
04 Apr 2012 15:08
#514041
Cool thanks for the responses guys. Very helpful
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
04 Apr 2012 22:20
#514095
Just contact Z1Enterprises and tell them what you got and what you want to do. Chances are very good they know exactly what you need and can sell the right stuff to you.
  • Zedone
  • Zedone's Avatar
05 Apr 2012 03:08
#514140
^ yep, what the boys said. Barnett also makes cables in case you were not aware. The Motion Pro would be my 1st pick though... they have a nylon insert in the jacket that reduces friction and work really well. The custom MP ones are really trick I like the steel braided jacket type with a clear jacket but they are pricey compared to the stock ones.
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • KZ802
  • KZ802's Avatar
06 Apr 2012 19:16
#514443
I took my old one off and went to my local Kawasaki dealer. They looked at everything they had in stock and found one that looked similar that was shorter. You just have to make sure the bend on the carb side of the cable is the same so it works the same on the carbs. I have a 1980 kz750LTD and the cable I bought off of them was (they told me) stock for a KZ550. It was cool because I could see it in person and compare to make sure I thought it would work and no waiting by the mailbox every day.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
07 Apr 2012 00:02
#514485
Z1 Enterprises is a distributor for Motion Pro
  • cherokeekid58
09 Apr 2012 23:59
#514936
Kz802, thats exactly what i was thinking. I like to be able to see and compare. I hate buying parts on the internets. Thanks yall ill check out Z1 enterprizes.
  • Rickman
  • Rickman's Avatar
16 Apr 2012 13:50
#516162
I switched my LTD from "buckhorn" to "daytona bars". I looked at the stock cable lengths and ordered cables for a "D" model. fit perfect.
Some sites tell you the lengths of the cables, or you can spend quality time with the parts diagrams.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
