rear brake tension spring
- Gar1800
31 Mar 2012 13:58
I just wanted to check with u all an show u a pick of this tension spring thats attached to the rear brake foot lever and cable, it doesn't look to be the right one to me. My foot goes down a lil further than I think it should to stop the bike. The rear hub brake maker shows "with a usable range". It seems a little long and maybe to thin? I will be getting a repair manual for this bike soon.
Attachment 105_3291.JPG not found
Re: rear brake tension spring
31 Mar 2012 14:26 - 31 Mar 2012 14:27The small spring prevents the brake light switch from being over-extended when the brake pedal is depressed.Gar1800 wrote: I just wanted to check with u all an show u a pick of this tension spring thats attached to the rear brake foot lever and cable, it doesn't look to be the right one to me. My foot goes down a lil further than I think it should to stop the bike. The rear hub brake maker shows "with a usable range". It seems a little long and maybe to thin? I will be getting a repair manual for this bike soon.
There's a separate adjuster at the end of the brake rod near the brake lever at the rear wheel.
It may be adjusted to require less pedal movement before the brake engages.
Last edit: 31 Mar 2012 14:27 by Patton.
- Gar1800
