18 inch rear mag wheel
- JBird
29 Mar 2012 14:14
Are there any 18 inch mag kz wheels that i can mount a 190 tire on and make fit my 78 1000 after i alter my swingarm of coarse!!!!! And will i have to do anything special to make the 41 tooth sprocket from my spoke wheel fit that wheel please help!! Sorry if its a stupid question!!! Thanks for tha help guys
- StreetfighterKz
Re: 18 inch rear mag wheel
29 Mar 2012 14:20
All the 18" mag wheels from Kz's are too narrow. The widest tire you may be able to squeeze on is a 130 and I think that's pushing it plus then you run into having odd handling issues.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
29 Mar 2012 14:26
79MKII has his rear mag wheel widened by someone to take a wider tire but if I recall correctly it was VERY expensive.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- mjg15
29 Mar 2012 14:28
Kosman gets $595/wheel to widen them. They can do whatever width that you want.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- JBird
29 Mar 2012 14:36
Ok thanks for the info. Sounds like im s.o.l. on the mags!!! Does anyone recomend another 18 or even a 17 inch wheel that will hold a 190 tire
- StreetfighterKz
29 Mar 2012 14:58
A 190 can be fit onto a 5.5" wide rim but really needs a 6" rim to fit properly. With that being said, you have several choices. You can either buy a sportbike rear rim or if you want you can have your spoked wheel relaced with a wider rim.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- JBird
29 Mar 2012 15:06
Ok thank you very much Doug. Il try to find out more info about havn my spokes relaced. I like that look anyways!!!!! Do u suggest any certian place??
- StreetfighterKz
29 Mar 2012 15:17
I just looked at the Custom Chrome catalog online. I know its for H@rley's but they have a 40-spoke 18"x5.75" rear rim for $149.99 (part #08776). You may have to get custom spokes from Buchanan for another $100 or so. It's not going to be as cheap as getting a sportbike rim but won't be as expensive has a Kosman widened Kz rim either.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- mtbspeedfreak
29 Mar 2012 15:42
Can Kosman widen mag wheels or just spoked wheels?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- StreetfighterKz
29 Mar 2012 17:31
I think Kosman only widen mag wheels. With the spoke wheels you can just relace a new rim.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
