Vmax swing arm on kz 1100
  • Darkangel
  • Darkangel's Avatar Topic Author
28 Mar 2012 15:10
#512551
In my attempt to get my 1100 to a cafe style, I ran across a vmax rear end and wondered could I get swap out the rear end with some mods? The vmax can fit a larger tire and they make heavier shafts for them. What are your thoughts on that?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Vmax swing arm on kz 1100
28 Mar 2012 16:36
#512576
i dont know anything about them. but i wonder if u will be able to match the drives together?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Darkangel
28 Mar 2012 20:48
#512626
When you say drives are talking about the splines and u joint. I was thinking if need be just taking the shaft from the vmax and from the kz and having them fitted, welded and then reinforced.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Mar 2012 10:46
#512724
another big consideration would be the width of the arm. if it is very much wider than the kz, u will need to cut widen and reweld the kz frame.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
29 Mar 2012 11:57
#512743
make sure which direction the output shaft of the v-max turns in relation to the direction the kz output shaft turns.
almost seems like i have heard they spin opposite of one another.
