83 kz440 ltd fork seal replacement
  • zaynesdaddy
  • zaynesdaddy's Avatar Topic Author
14 Mar 2012 21:55
#509699
I want to replace my fork seals but not sure how to do it. Anyone have any tips on doing this??
Re: 83 kz440 ltd fork seal replacement
14 Mar 2012 22:08
#509703
zaynesdaddy wrote: I want to replace my fork seals but not sure how to do it. Anyone have any tips on doing this??
Hello, and WELCOME to KZr!
Absent the FSM, might find a step-by-step through one of these links:
www.armbell.com/forum/index.php?c=6&sid=...571a51a&mforum=kz400
www.kz400.com/
Good Fortune! :)
  • martin_csr
  • martin_csr's Avatar
Re: -
15 Mar 2012 09:49 - 20 Feb 2013 12:25
#509780
The first fork can be hard, but the learning curve is steep... after doing one, the 2nd is easy.
What's hard is figuring out how to get 'em apart & stuff is usually stuck.
Last edit: 20 Feb 2013 12:25 by martin_csr.
  • DaddyJama
  • DaddyJama's Avatar
15 Mar 2012 13:14
#509818
I did mine on an 82.. The first one took 3 hrs. The second tool about 20 mins:)
Mt biggest headache was the ring that held the plate in the tubes ..
I could not get enough spring force off the plate to get the ring out.. Soon ended up using two arm pullers
Long story short, I replaced the little rings with snap rings so I can use snap ring pliers on the future.
2005 636 - track bike
1982 kz440ltd - new toy;)
  • martin_csr
Re: -
15 Mar 2012 17:27 - 20 Feb 2013 12:25
#509844
Didn't someone mention a tool or something in your fork topic?
I kinda remember that he mentioned a handy tip to make the job easier.
  • DaddyJama
15 Mar 2012 21:56
#509913
martin_csr wrote: Didn't someone mention a tool or something in your fork topic?
Yep. Two arm puller.
www.google.com/search?tbm=isch&source=mo...&biw=320&bih=356#p=0
Worked like a charm. I'd recommend this for Any that don't have a screw off type fork..
