Brake Hoses
  • badrhino
  • badrhino's Avatar Topic Author
Brake Hoses
14 Mar 2012 18:53
#509667
I have had some of these parts off and sitting for a year or two and now I noticed that my brake hose ends look to have old brake residue or rust in them. Is it OK to clean them up and use them?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Re: Brake Hoses
14 Mar 2012 21:29
#509692
badrhino wrote: I have had some of these parts off and sitting for a year or two and now I noticed that my brake hose ends look to have old brake residue or rust in them. Is it OK to clean them up and use them?
brake hose ends :unsure: the banjo fittings?
Good Fortune! :)
  • badrhino
Re: Brake Hoses
14 Mar 2012 23:39
#509731
Yes sir, the banjo fittings.
Franken Z!
Re: Brake Hoses
15 Mar 2012 00:28 - 15 Mar 2012 00:54
#509745
It's difficult to say without a picture, but nasty brake fittings and parts may often be restored to serviceable condition.
If using a cleaning agent other than brake fluid, would avoid allowing any of it to get into the inside of the brake hose. And purge the hose interior with fresh brake fluid.
I use common household rubbing alcohol to clean brake master cylinder and caliper parts during the renovation process.
But if allowed to enter the brake hose, be sure to purge the hose with fresh clean brake fluid.
Good Fortune! :)
Last edit: 15 Mar 2012 00:54 by Patton.
  • badrhino
Re: Brake Hoses
15 Mar 2012 00:40
#509748
Ok thanks, I just don't want to spend the money on all new lines when in the next year or so I would like to upgrade suspension front and rear.
The hoses and everything look fine they just had a rusty-ish looking residue inside the banjo fittings. My master cylinder was kinda funky also, but I got it cleaned up.
Franken Z!
