BRAKE ISSUE ON KZ750 Spectre 1982!
  • Hawk111
  • Hawk111's Avatar Topic Author
13 Mar 2012 18:22
#509453
Ok, when I got the bike the rear brakes work ok, however the front are just super weak.
There is a dual disc system on the front tire I am guessing for stronger stopping power.
How do I make these brakes work again on the front.
Also in correlation with this is front brake issue is the fact that I removed the wheels and put new tires on myself. I took the rims and had new tires put on and the old rubbers removed.
I proceeded to head back home and from there I put the newly tire mounted rims on the 750 Spectre.
For some reason when I put the discs back into the calipers the brake pads grip the discs too much and are too tight on both rear and front.
1. How do I adjust these brake pads amount of grip
and
2. How do I make the front brakes work again?
  • ramtough_63
  • ramtough_63's Avatar
Re: BRAKE ISSUE ON KZ750 Spectre 1982!
13 Mar 2012 19:08
#509456
ok not sure what you mean the pads were to0 tight on both and you dont have front brakes but let me ask you this
did you crack the bleeders and spread the calipers open enought to get the wheels back on?
if not
open the bleeders and bleed brakes til pedal/lever feels right make sure you keep fluid topped off
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
13 Mar 2012 19:20
#509457
When is the last time you flushed the brake fluid and bled the brakes? If you answer is "I can't remember" it's overdue. ;)
  • Hawk111
15 Mar 2012 12:13 - 15 Mar 2012 12:20
#509814
Hey man, I don't know where the bleeders are.
the break pads, they were just too snug on the discs I don't know why
is it just basic break fluid i use?
Last edit: 15 Mar 2012 12:20 by Hawk111.
15 Mar 2012 12:29 - 15 Mar 2012 12:30
#509816
Hawk111 wrote: Hey man, I don't know where the bleeders are.
what kind of fluid do I use
Bleeder nipples are usually located on the calipers.
As earlier suggested, spread the pads before installing the wheel.
The pads are designed to self-adjust their position against the disc.
Fluid type is usually imprinted on top of the reservoir cap.
The original type brake fluid isn't DOT-5 silicone based fluid.
In event a previous owner has converted to DOT-5 silicone based fluid, don't mix DOT-5 silicone based fluid with any other type brake fluid.
Good Fortune! :)
Last edit: 15 Mar 2012 12:30 by Patton.
  • nobody
  • nobody's Avatar
15 Mar 2012 15:42
#509834
has the bike been sitting a long time ?
15 Mar 2012 16:06
#509836
Use DOT 3 or DOT 4. DO NOT USE DOT 5.
