Brake line suppliers
  • bluej58
  • bluej58's Avatar Topic Author
12 Mar 2012 12:55 - 12 Mar 2012 13:38
#509207
I have procrastinated long enough and am starting to worry that I will be able to get my bike running but will not be able to stop it :woohoo:
I've been checking with some of the suppliers that have been mentioned here and this is what I have so far.
I'm looking for braided S.S. plastic coated brake lines that are premade for my stock kz 1000
Russel ; To big to talk to me and I guess I need to find a local dealer, which means more time and money than I want to spend right now. www.russellperformance.com/motorcycle/dl/07RussMetricCat.pdf
Cycle Brakes ; has Galfers with all the banjo bolts and washers for around 160.00 ( I'm guessing )
www.cyclebrakes.com/html/galfer_brake_lines.html
Apex Brakes ; I have sent them 2 emails asking about the connection size 10 mm x 1.25 ,washer availability , turn around time , and if there is a number that I can reach some at, but they have not gotten back to me.
apexbrakes.com/custom.asp
Their order form is very easy to understand and use but it only says 10 mm .
I don't want to get the wrong stuff.
I really like their prices and I don't need new bolts.
Any incite on another supplier or how to work with one of these would be appreciated.
JD
78 KZ1000 A2A
Last edit: 12 Mar 2012 13:38 by bluej58.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: Brake line suppliers
12 Mar 2012 15:59
#509227
Z1enterprises. ;) You wont be sorry, or should I say I'm not sorry.
Les
12 Mar 2012 16:09
#509228
Be sure to specify the correct angles for the connectors. I've seen some installations where the wrong connectors were used resulting in the brake lines sticking out at weird angles. Ed
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
12 Mar 2012 17:18
#509239
i have used the universal russell lines from Z1E. they worked fine.
i also have the custom Galfers from Cycle brakes, wich are fine.
i'd say, for cost go with Z1E, for custom colors go with Galfer.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • MFolks
  • MFolks's Avatar
12 Mar 2012 17:22
#509241
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
12 Mar 2012 18:32
#509255
I bought all my brake lines from redline cycle and bought my speedbleeders factory direct.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
12 Mar 2012 19:26
#509261
u want 10 mm. the bolts for all jap bikes are 10.25mm.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • bluej58
12 Mar 2012 20:17
#509263
Thanks for the great responses,
When I talked to the guy at Z1E I was under the impression that they didn't sell them.
I must have been mistaken.
I would love to use Rusell lines , they're American made I think.
So I have to put them together, no big deal right ?
Do the ends just spin on ?
I have to give them a call tomorrow any ways so this will work out great !
Lengths , angles and orientation of the ends all figured out .
I would have liked to use Red line more because they are in the Chicago area , but with as much money as I've been throwing at this project it just isn't frugal paying another 8 percent state tax.
I know they have some real nice stuff.
Thank you MFolks , I have a lot to read tonight.
JD
78 KZ1000 A2A
13 Mar 2012 00:00 - 13 Mar 2012 00:01
#509326
Click > www.z1enterprises.com/searchresult.aspx?...eyWords=brake%20hose
Start looking at page 6.
Good Fortune! :)
Last edit: 13 Mar 2012 00:01 by Patton.
  • bluej58
13 Mar 2012 16:23
#509444
Thanks Patton, I couldn't find them on Z1E for some reason and Hughesnet has been down for the last 14 hours :pinch:
JD
78 KZ1000 A2A
