take a look so far
  • jmcmillan40
  • jmcmillan40's Avatar Topic Author
take a look so far
11 Mar 2012 01:54 - 11 Mar 2012 01:57
#508982
lots of mods,coils,blue headlight,barend mirrors,gold chain,stage 3 carb kit,kirker 4-1,dyna 3000 ignition,plug wires, front braided lines,81 sr650 motor, ,92 gsxr 750 fonr end, rear disk conversion, kawasaki 750 swing arm with 16" rim,taperd steering bairings,chome master-brake handle, acewell guage. header rap.
new paint comming and soon to be polished 78 650 motor
I installed the 1992 gsxr 750 front end on my bike, but i would like to do away with the fork mount handle bars
and get the kind that mount on top of the triple t, but my triple doesnt have a place to bolt on the handlebars.
do they make a set of risers that can be bolted onto the top of my triple?
also take a look at my front tire-rim, any suggestions on a differnt rim/tire that would mount on - forks? gsxr 1000? i would like a bigger profile.
bottom line i like the gsxr triple/ fork conversion but i want a better stearing system with more height? how about a differnt fork-rim-tire-rotor-caliper that would work with the 92 750 triple?
or do you think installing handlebars on top with risers would help with low riding postion and handleing?
what would you do with this front end. the rear rim is a 16" 750 ltd disc conversion
the front is a 17inch rim.
Last edit: 11 Mar 2012 01:57 by jmcmillan40. Reason: forgot
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: take a look so far
11 Mar 2012 11:11
#509028
Nice work. Roy
  • ramtough_63
  • ramtough_63's Avatar
11 Mar 2012 12:56
#509050
Looks great man
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • btchalice
  • btchalice's Avatar
11 Mar 2012 17:04 - 11 Mar 2012 17:10
#509075
from what ive read the 1000 gsxr forks same era are 1.5 to 2 inches longer
i need them to lift this one a bit too
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
Last edit: 11 Mar 2012 17:10 by btchalice.
  • gwolever
  • gwolever's Avatar
11 Mar 2012 22:46
#509136
Looks great. How did it go hooking up that Acewell? I just ordered one myself. Is it a pretty simple process? How about calibrating it?
1982 KZ1000 CSR
  • jmcmillan40
11 Mar 2012 22:50
#509137
well i baught it with acewell on it so i cant realy help on that
sorry
  • jmcmillan40
11 Mar 2012 22:55
#509138
i still have yet to calibrate with new fron end
I like what you have done great job, see thats what i want to do with mine, how you have handlebars up top instead of on forks,
i think i will have to get some risers that I can drill tap and install on the top ot triplet
would I be able to get a gsxr 1000 front end that would mount right into my 750 triple?
  • btchalice
13 Mar 2012 14:46
#509432
i used the clamps from an old triple top with single bolt from the bottom and drilled the top gsxr clamp , i had it drilled pre spaced to go with a harley riser setup for 1 inch bar but i havent found a cheap set of 1 inch controls yet
