mounting an 83 gs1100e swingarm
- Reaper40
10 Mar 2012 16:25
i have currently purchased a 83 gs 1100e swingarm for my 76 kz900.
i was told that it was a dirrect fit but am noticing the axle from my 76 is not fitting through the swing arm.
sooooo.....
is there anyone who has fitted oneof these to a 76 and if so can you please help out a over his head amature please?
sooooo.....
- jonnybravo
- Banned
Re: mounting an 83 gs1100e swingarm
10 Mar 2012 19:44
I had no problem at all, more details would be helpful, measurements, perhaps a photo
- MTH76
13 Mar 2012 09:06
Did you get the GS axle with the swing arm?
If not you will need it because the GS swing arm is wider.
You will also need to add washers to each side of the swing arm mounting bolt inside the frame.
I am in the middle of this project myself.
I looked at past build threads to help me alot.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
The following user(s) said Thank You: Reaper40
