kz-gsxr front end
  • jmcmillan40
  • jmcmillan40's Avatar Topic Author
kz-gsxr front end
09 Mar 2012 22:17 - 09 Mar 2012 22:45
#508791
so i decided to to a front end swap I used a 1992 gsxr 750, bottom neck baring worked strait swap.
I had a machine shop make me a special nut fro upper triple, that would recess down into bairing.
worked great.
I also put a 81-ltd 750 swing arm on and fabricated the mount for rear master.
works great its a 16" rim.
the rim om my front end is a 17" but it has the stock tire from the gsxr on it. and it is a low pro.
so i would like some options to equal out the front with the rear.
A# could I just get a bigger tire installed on rim?
B# i think the rim is bent so is there a rim- tire that would work with that front end?
c# or is there a front end ie (forks-rim-rotor-caliper that would fit the gsxr triple i put in?
i would like longer forks becuase they are short and work but with the bolt on hand grips the rideing position it low, like like around the top of tank.
any help would be great,
ps i no there has to be a gsxr front end that will slip into the 750 triple just dont no witch one
Last edit: 09 Mar 2012 22:45 by jmcmillan40. Reason: picture
  • jmcmillan40
Re: kz-gsxr front end
09 Mar 2012 22:46
#508794
here is a picture
  • jmcmillan40
09 Mar 2012 22:55
#508799
09 Mar 2012 23:26
#508807
Windows 7
Attachment picpostnewsite.jpg not found
  • jmcmillan40
09 Mar 2012 23:40
#508808
it says fatal errror
when i try
its 2.8 megs is that why
  • jmcmillan40
09 Mar 2012 23:41
#508809
bike
  • jmcmillan40
09 Mar 2012 23:46
#508810
kz picture
  • ramtough_63
  • ramtough_63's Avatar
10 Mar 2012 00:03
#508815
nice looking bike good job
if your delimma is putting a taller tire on there what size is your front tire 120/70?? you can get a taller tire a 120/90
if its your ride angle you can get some handlebat risers and put a set of super bars or drag bars and thet would help
hell do both
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
10 Mar 2012 00:03
#508816
When including a pic within an outgoing message,
it's best to keep pic size within the following limits:
Width: 2400px
Height: 1200px
Size: 2048kb (2 MB)
Good Fortune! :)
  • jmcmillan40
10 Mar 2012 02:24
#508841
thanks i still have some work to do.
it just seams like it handleing is kinda short.
i like the front end, and i thin the 16 in rim goes well with the front, just dont like the slim tire, would like to ballance it out.
i think your right, i need to get the handle bars up a little.
so you would you get rid of the bolt on handle bars. how would i get handle bars on there.
there is no handle bar mounts.
