Tire size...
  • fizzer_$tfighter
  • fizzer_$tfighter's Avatar Topic Author
  • YAMASAWKI MAN
Tire size...
08 Mar 2012 15:02
#508549
So I have a stock rear wheel on my 82 KZ 1000, needs new rubber. Mt question is what is the largest tire it can safetly handle...110 just aint cuttin it...
82 KZ 1000 J Model
Re: Tire size...
08 Mar 2012 16:15
#508565
What model '82 KZ1000 ?
  • fizzer_$tfighter
  • YAMASAWKI MAN
Re: Tire size...
08 Mar 2012 16:26
#508568
J model
82 KZ 1000 J Model
Re: Tire size...
08 Mar 2012 16:53 - 08 Mar 2012 16:53
#508573
From what I can find the '82 KZ-1000 J has the same size stock rear wheel (2.15x18) as my KZ650-C1. I run a 120/90-18 Pirelli Sport Demon on the rear and it works well (Pirelli Sport Demon 100/90 19 on front). In the past I ran 130/90 18 Michelin tires on the rear and that is the largest that will fit on the stock rim without rubbing hard stuff. BUT - I have found that the 120 works every bit as well as the 130. This is because the 130 must be really squeezed onto the rim and this deforms the cross section of the tire somewhat. This deformation results in reducing the contact patch of the tire to about the same as the 120. The 130 looks cool on the bike, but to me it's not worth the struggle to mount it on the rim since there's no functional advantage. Also, I had to replace my stock chainguard with a custom job because the 130 rubbed. The 110 is recommended in some of the tire fitment guides, but it's too narrow for me. Ed
Last edit: 08 Mar 2012 16:53 by 650ed.
  • ramtough_63
  • ramtough_63's Avatar
Re: Tire size...
08 Mar 2012 17:00
#508575
my 78 had a 130 on it when I got it no problems at all if I had not swapped swingarms I would still be running it
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
The following user(s) said Thank You: fizzer_$tfighter
  • fizzer_$tfighter
  • YAMASAWKI MAN
Re: Tire size...
08 Mar 2012 17:20
#508580
Cool, im going to go with the 120, I dont want rubbing.
Swingarm build planned. So ill go big then
82 KZ 1000 J Model
Re: Tire size...
08 Mar 2012 17:21
#508581
650ed wrote: ... I have found that the 120 works every bit as well as the 130. This is because the 130 must be really squeezed onto the rim and this deforms the cross section of the tire somewhat....
Yes, the 130 reminds of a fat belly pooching out over a too tight waist band. :lol:
Good Fortune! :)
  • fizzer_$tfighter
  • YAMASAWKI MAN
Re: Tire size...
08 Mar 2012 18:58
#508605
Of course there is a 130 on there...idk
82 KZ 1000 J Model
  • RonKZ650
  • RonKZ650's Avatar
Re: Tire size...
09 Mar 2012 00:54
#508674
You can also get the 4.00-18 which is the correct tire and no a 110/90-18 is "not" the same. A 110/90 is junk, a 4.00-18 is damn near perfect, but choices are limited. A 120/90-18 works and is larger which is what most guys prefer.
  • fizzer_$tfighter
  • YAMASAWKI MAN
Re: Tire size...
09 Mar 2012 01:01
#508676
ramtough_63 wrote: my 78 had a 130 on it when I got it no problems at all if I had not swapped swingarms I would still be running it
What swingarm did you put on?
82 KZ 1000 J Model
  • fizzer_$tfighter
  • YAMASAWKI MAN
Re: Tire size...
09 Mar 2012 01:05
#508677
RonKZ650 wrote: You can also get the 4.00-18 which is the correct tire and no a 110/90-18 is "not" the same. A 110/90 is junk, a 4.00-18 is damn near perfect, but choices are limited. A 120/90-18 works and is larger which is what most guys prefer.
Any suggestions on tyres? Model/make that meet your spec?
82 KZ 1000 J Model
  • ramtough_63
Re: Tire size...
09 Mar 2012 01:14
#508678
it had a stock dixc brake swingarm with a 130 when I bought it i currently have an 03 ZX6 swingarm with a 190 tire I just finished thanks to the help of the uys on here
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
