possible rotor swap?
- kronus
06 Mar 2012 17:06
hi all, long time lurker, first question. what possible rotor swaps are there for larger diameter rotors on the 1981 kz750 4 cylinder bike with the Enkei mags?
thanks.
thanks.
- TeK9iNe
- What did you do!?!
Re: possible rotor swap?
06 Mar 2012 17:51
I dont think you can go much larger diameter rotor, as you will likely have to change out the caliper as well - to provide for extra clearance.
Might be best to just measure up max possible rotor size you could handle (diameter, offset, bolt count, spacing, etc.), then go to a wreckers and check out your options.
Better upgrade is to swap out calipers and lines for multipiston and steel braided.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- BlackZ1R
- Kawasaki in my blood
06 Mar 2012 23:41
The factory rotors are plenty big. Get the brakes operating properly and then go with SS lines. It should stand you on your nose.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
