KZ1000 Front Disc/Rotor Thickness
  • 750steve
  • 750steve's Avatar Topic Author
06 Mar 2012 11:53
#508108
Can amyone tell me what thickness the OE discs/rotors were please for the following models, they all used the same disc.
Drilled/Ventilated
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
Non - Drilled (same disc with no holes
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ900-B1 (LTD) (1976)
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • z1kzonly
  • z1kzonly's Avatar
Re: KZ1000 Front Disc/Rotor Thickness
06 Mar 2012 12:36
#508113
Big Bikes use 7mm rotors, with a 6mm minimum.
Some smaller KZ's use 5mm rotors
  • z1kzonly
  • z1kzonly's Avatar
06 Mar 2012 12:43
#508114
  • 750steve
06 Mar 2012 13:15 - 06 Mar 2012 13:17
#508118
Are you sure? Yhe KZ1000 rotors/discs i have say 'MIN 4.5mm' on the back, they're the ones i need the original thickness of. My Discs are ok but are slightly uneven on the rear face. I have the single disc off a 1977 KZ750 Twin & a 1977 KZ650 (both the same disc), they measure near 7mm wide with v little wear. I was going to get each disc machined down to match the spec OE thickness of the discs i posted in my 1st post here, i'd have discs as good as new then.
So did the 'Min 4.5mm' Discs start life at 5mm?? Thats all i really need to know.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 06 Mar 2012 13:17 by 750steve.
  • steell
  • steell's Avatar
06 Mar 2012 14:29 - 06 Mar 2012 14:29
#508124
Single disk front brakes use a 7mm rotor, dual disk front brakes use a 5mm rotor.
Last edit: 06 Mar 2012 14:29 by steell.
The following user(s) said Thank You: 750steve
06 Mar 2012 15:40 - 06 Mar 2012 15:51
#508130
Steell wrote: "Single disk front brakes use a 7mm rotor, dual disk front brakes use a 5mm rotor. "
That's exactly what my KZ650 manuals show:
KZ650 B models – single front - effective diameter = 250mm; thickness = 6.9 - 7.1mm; Limit = 6mm; rear brake = drum
KZ650 C and D models – dual front - effective diameter = 231mm; thickness = 4.9 - 5.1mm; Limit = 4.5mm; rear brake effective diameter = 237mm; thickness = 6.9 - 7.1mm; Limit = 6mm
Last edit: 06 Mar 2012 15:51 by 650ed.
  • 750steve
06 Mar 2012 16:04
#508136
Thank you very much guys.
Just been told by my local machine shop that he can't machine bike brake discs as they're made from 318 Stainless...........now i don't know if that means HE cant machine them or they cant be machined at all.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
06 Mar 2012 16:26
#508139
They can be done, but not using regular car brake equipment. It takes special grinding equipment. Here's a link to a place that does them:
www.truedisk.net/
  • 750steve
06 Mar 2012 17:38
#508147
Some nice info about the process there Ed, thanks. Shipping would make it a very costly option for me though. I'll see if anywhere else local can do it.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
06 Mar 2012 17:44
#508148
My CSR are 4mm front, 6mm rear.
Lots of rotors for different years though... and then there's aftermarket :pinch:
Best to just check with OEM. Or is might be stamped on the disc somewhere.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • bountyhunter
  • bountyhunter's Avatar
06 Mar 2012 22:45
#508208
I thought the thickness was stamped on the rotor somewhere(?)
  • 750steve
06 Mar 2012 22:57
#508211
Minimum thickness is stamped on it, i'll go check here to make sure & report back in this post.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
