KZ550 LTD Clutch Cable with Superbike Handlebar
- Johnny NoPants
01 Mar 2012 09:50 #507160
by Johnny NoPants
Johnny NoPants
1981 KZ550 LTD
KZ550 LTD Clutch Cable with Superbike Handlebar was created by Johnny NoPants
I replaced the handlebar on my 81 KZ550 LTD with a Superbike handlebar. My clutch cable is now a nightmare to route and keep out of the front wheel. I have heard that a GPz clutch cable is the solution. Which year cable is right for this application, and will it be a direct replacement? I noticed, from pictures, that the GPz cable is significantly different from my LTD cable.
Johnny NoPants
1981 KZ550 LTD
- Kawickrice
- Thank you received: 20
01 Mar 2012 11:03 #507166
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic KZ550 LTD Clutch Cable with Superbike Handlebar
Contact Motion Pro and they will make a custom length cable for you
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- KZJOE900
- Administrator
Super Users
01 Mar 2012 11:32 #507170
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic KZ550 LTD Clutch Cable with Superbike Handlebar
If you look up the replacement cable for your original clutch cable at Z1Enterprises, you will see a recommendation for a shorter replacement cable. Or a longer recommendation replacement cable as well for people that require that solution. The Z1Enterprises cables that I received were also motion Pro. Good luck.
Joe
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 1648
01 Mar 2012 12:26 - 20 Feb 2013 12:27 #507172
by martin_csr
Replied by martin_csr on topic -
Disconnect the cable at the lever, then position it & figure out the overage. When the position looks about right, I would tape it securely to the bars, then turn the handlebars front from side to side to make sure there is no binding or anything. Remove the cable from the bike & measure it ... subtract the overage, then get one made or find one at Z1... cables there have the measurements.
Last edit: 20 Feb 2013 12:27 by martin_csr.
- loudhvx
- Thank you received: 1622
01 Mar 2012 16:34 #507204
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic KZ550 LTD Clutch Cable with Superbike Handlebar
Yes, Motion Pro can make the clutch cable any length you want. BUT order as soon as possible. This mild winter has really ramped up business for them and they are on a backlog.
1981 KZ550 D1 gpz.
Other links.
