Spoked wheels for 1981 KZ750?
  • rhb629
  • rhb629's Avatar Topic Author
28 Feb 2012 19:10
#506889
Is it possible to fit spoked wheels on an '81 KZ750? I've been looking around but haven't found anyone who's actually done this, just ideas. I need new tires and fork seals, so it would be a good time to try it.
For the front, I know some KZ900's and KZ1000's had spoked dual disc wheels. The problem is those have 17mm axles whereas mine is 15mm. I suppose the legs or maybe even the whole front end would have to be switched out to accommodate the larger axle.
If I reduced down to a single disc in the front, I think a wheel from an 80's KZ650 CSR, 70's CB750, or 70's CB550 might fit.
The rear axle on my bike is 17mm with a disc brake. If I switched out the swing arm would a rear wheel from a 70's KZ750 twin (20mm axle) fit into the existing caliper? I don't have a welder, so relocating either caliper isn't a possibility.
Interested to hear from anyone who has done this before.
1978 Kawasaki KZ650B
1981 Kawasaki KZ750-E2 ( kzrider.com/forum/11-projects/506846-1981-kz750-e2-project )
1973 Honda CB350G
1981 Honda CM400C (sold)
1986 Honda CMX250 (sold)
  • martin_csr
  • martin_csr's Avatar
Re: -
28 Feb 2012 19:47 - 19 Feb 2013 14:06
#506895
Last edit: 19 Feb 2013 14:06 by martin_csr.
