Too Long of Chain!
Re: Too Long of Chain!
23 Feb 2012 14:23badrhino wrote: I never thought about putting safety wire around the link with the clip. :woohoo: Does that stay secure and not cause any problems?
yessir,that is the method used by road racers for years.
there is just enough of a gap for the safety wire to live in between the links and the sprocket.
give it a look,you will see what i mean.
- badrhino
23 Feb 2012 15:37
I do believe I'll do this on mine.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- xbmxxx
27 Feb 2012 01:06
If you aren't going to use it often, Harbor Freight sells a chain breaker for $9.99. I just got one for my 530 and it worked fine.
76 KZ750B Twin
