Too Long of Chain!
- badrhino
Too Long of Chain!
22 Feb 2012 20:18 - 22 Feb 2012 20:28
So I ordered my new 530 chain and sprockets from a certain company and I gave them the sprockets sizes I wanted and they sent the chain and sprockets that was supposed to fit said set-up.
As you can see by the pics. I am now going to have to remove some links. This is why I ordered it so I wouldn't have to remove links!
The last picture is with the wheel pulled all the way back and it is still loose.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
Last edit: 22 Feb 2012 20:28 by badrhino.
Re: Too Long of Chain!
22 Feb 2012 20:57
If it's an endless loop chain (no master link) send it back.
- badrhino
22 Feb 2012 21:02
It has a master link I just figured when I ordered it they would send what would be the right size (length) for the bike and appropriate sprockets. Now I'll have to work on it to make it fit.
Franken Z!
Franken Z!
- badrhino
22 Feb 2012 21:03650ed wrote: If it's an endless loop chain (no master link) send it back.
How would you use a endless loop chain? lol
Franken Z!
Franken Z!
22 Feb 2012 21:10 - 22 Feb 2012 21:11badrhino wrote:650ed wrote: If it's an endless loop chain (no master link) send it back.
Endless loop o-ring chains came standard on many, if not all, model KZ's (for sure on KZ650's). To replace the chain with another endless loop chain you must remove the swingarm so you can get the chain around the countersprocket. This is probably the reason not many folks replace the original chain with another endless loop. Ed
Last edit: 22 Feb 2012 21:11 by 650ed.
- badrhino
22 Feb 2012 23:03
Ahh, I see. That would be a PITA. :S
Anyhow I thought when you ordered these 530 chains/sprocket sets from Z1 that they were to send a chain that would be ready to go! :dry:
Franken Z!
Franken Z!
22 Feb 2012 23:08
I would give Jeff at Z1 a call and ask. Maybe he wasn't sure which model you have or how many links you needed. Ed
23 Feb 2012 13:38
i have had to shorten every chain i ever bought.
i dont care what is was for dirtbike,streetbike,quad had to shorten all of em.
- badrhino
23 Feb 2012 13:43
How do I know when to stop shortening it? Do you want the slack set right just at the beginning of the swing arm adjustment (all the way forward)?
I bought a setup for a TL one time and it fit perfectly.
Franken Z!
Franken Z!
23 Feb 2012 13:52 - 23 Feb 2012 13:53
yessir slide the axle all the way forward and put one end of the chain on the rear sprocket so it will hold it on.
then fold the chain over right where it meets the end and then make sure everything is good and grind the ends off and use a punch to separate the link,and a chisel may be needed to get the plate off.
then put your masterlink on.
you may need to use a c-clamp or vise grips to squeeze the link back together and put the circlip back on.
a wrap of safety wire helps to makes sure the clip can't come off.
hth,
hth,
Last edit: 23 Feb 2012 13:53 by 531blackbanshee.
- badrhino
23 Feb 2012 13:58
I never thought about putting safety wire around the link with the clip. :woohoo: Does that stay secure and not cause any problems?
Franken Z!
Franken Z!
- nobody
23 Feb 2012 14:06
all ways had to shorten um .the clip goes on like in last pic.other way wrong .maybe that was said and i missed it good luck happy trails
