1980 Kz440 ltd sprocket size change
- AngloBiker
19 Feb 2012 13:21
Hello, I'm new here, and I would like to know if any one has change either the front or rear sprocket for better highway cruising, semse the bike was made when speed limits wher 55mph. I know the bike will do 65mph no problem but o'm looking for better fuel economy seeing I comute 120 miles plus a day. Dose any one know what sprockets will fit from other bikes to help me achieve this?
Thanks ahead of time for your input.
Re: 1980 Kz440 ltd sprocket size change
19 Feb 2012 13:41Hello, AngloBiker, and WELCOME to KZr!AngloBiker wrote: Hello, I'm new here, and I would like to know if any one has change either the front or rear sprocket for better highway cruising, semse the bike was made when speed limits wher 55mph. I know the bike will do 65mph no problem but o'm looking for better fuel economy seeing I comute 120 miles plus a day. Dose any one know what sprockets will fit from other bikes to help me achieve this?
If a replacement countershaft sprocket with one more tooth is available, could install it and test run.
Acceleration will suffer, but cruising rpm might feel more relaxed.
Am doubtful about any significant difference in fuel consumption.
Would bear in mind that these engines were designed and meant to spin happily at rpm's below redline.
Better fuel economy might be better achieved by careful attention to engine maintenance (spark plugs; valve clearances; ignition timing; clutch push rod adjustment; etc.) and carb tuning (clean air filters; fuel level; etc.) and chassis maintenance (tire pressure; no brake drag; chain lubed and kink-free; wheel bearings; etc.)
- bountyhunter
19 Feb 2012 20:56
I doubt it will inrease mileage much if any (did not on my 750 twin). It will cruise smoother.
- Rainman
- and a little Kaw shall lead them
20 Feb 2012 20:22 - 20 Feb 2012 20:35
AngloBiker, I put a 16 tooth (+1) front sprocket on a 81 440 and it dropped about 400 RPM at 65 MPH.
I got the front sproket from Z1Enterprizes P/N SS515-16 (about $17.00).
Good luck, And Welcome
Jim
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 20 Feb 2012 20:35 by Rainman.
- MFolks
20 Feb 2012 22:15
Use
www.gearingcommander.com
when changing the engine or rear wheel sprockets.
- bountyhunter
21 Feb 2012 02:34 - 21 Feb 2012 02:34Not often considered, but a good fairing which reduces drag will significantly increase highway mileage. Not a vertical windshield which acts like an air brake but something that punches a hole in the air for the bike. It also will improve your comfort.AngloBiker wrote: I know the bike will do 65mph no problem but I'm looking for better fuel economy seeing I comute 120 miles plus a day.
Last edit: 21 Feb 2012 02:34 by bountyhunter.
- Rainman
21 Feb 2012 02:53
Jim
Quincy,IL
Jim
Quincy,IL
- bountyhunter
21 Feb 2012 05:16
I recognize the backside of a KZ750 twin over there to the right with stock exhaust...... takes me back to when mine was new.
- AngloBiker
21 Feb 2012 19:04
Thank you everyone for your input. Think I will get a windscreen to add for comfort and I will also check the valves and make sure carbs are tuned and working well before I change the front sprocket
- hypnohio
21 Feb 2012 19:13
nice looking bike. what kind of saddlebags are those, and were the rear turn signals moved? thanks.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
2003 EN500 C
2006 Virago 250
- Rainman
22 Feb 2012 02:50 - 22 Feb 2012 02:51
hypnohio, the bags are Willie & Max Compact Braided Slant Saddlebags, Dennis Kirk P/N 50-5933.
Yes the turn signals were moved to the rear light bracket
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 22 Feb 2012 02:51 by Rainman.
22 Feb 2012 09:28
Rear signals relocated to simple bracket fitted between tag and mount.
For easy fitment of soft bags.
Also handy for bungee cord hooks.
