KZ 1000 SHAFT DRIVE/FINAL DRIVE REBUILD
  • juliorice
  • Topic Author
18 Feb 2012 23:59 #504963 by juliorice
KZ 1000 SHAFT DRIVE/FINAL DRIVE REBUILD was created by juliorice
Hello. I'm trying to resurect a 79 KZ1000 shaft drive. I took the rear end apart to clean it up and I am trying to dissasemble it. Can anyone tell me how to get the ring gear assembly apart. It seems that some components are pressed together. I want to get to the bearing that is in the outer housing and under the ring gear. Can anyone offer some insight to this situation. Any help would be very appreciated. Thanks. Julio
19 Feb 2012 00:52 #504972 by Nebr_Rex
Replied by Nebr_Rex on topic KZ 1000 SHAFT DRIVE/FINAL DRIVE REBUILD
Why?
Is it bad?
I'm on my third KZ1000st and never had a problem with the final drive.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • juliorice
  • Topic Author
19 Feb 2012 01:31 - 19 Feb 2012 01:32 #504977 by juliorice
Replied by juliorice on topic KZ 1000 SHAFT DRIVE/FINAL DRIVE REBUILD
When I got the KZ it was clear that the drive shaft was left open to the elements. As a result the final drive gear housing filled up with water. I took it all apart and cleaned it all up, but when I would turn the input gear it would bind up. You could turn it past the binding. It would go through in this thump thump fashion. A little difficult to explain. It seems that the binding is occuring in the large bearing in the ring gear housing. If that's what it's called. It's not really a housing, but I think you get it. This is why I want to take it apart. Thanks.
Last edit: 19 Feb 2012 01:32 by juliorice.
