tank swap..how to swap petcocks
  • DaddyJama
  • DaddyJama's Avatar Topic Author
08 Feb 2012 02:19
#502739
how can i get a,
Attachment IMG_3492_2012-02-08.JPG not found
to look like b?
Attachment IMG_3493.JPG not found
2005 636 - track bike
1982 kz440ltd - new toy;)
  • ramtough_63
  • ramtough_63's Avatar
Re: tank swap..how to swap petcocks
08 Feb 2012 02:22 - 08 Feb 2012 02:25
#502741
an adapter plate i bought a tank from ebay with one on it search pingel i have seen them but cant remember where other than on the tank i bought
the one i just found on ebay is crazy price but comes with petcock
Attachment pingeladapter.jpg not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 08 Feb 2012 02:25 by ramtough_63. Reason: looked up photo
08 Feb 2012 07:21
#502752
Might check the adapter plates available at Z1E.
Good Fortune! :)
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
08 Feb 2012 09:28 - 08 Feb 2012 09:31
#502759
Read this. I don't think you can go from round to oblong.
I had to get a plate that moved the petcock so it wouldn't hit my carbs. Roy
www.z1enterprises.com/reference/petcock.aspx
Last edit: 08 Feb 2012 09:31 by roy-b-boy-b.
  • martin_csr
  • martin_csr's Avatar
Re: -
08 Feb 2012 10:42 - 19 Feb 2013 12:50
#502774
Last edit: 19 Feb 2013 12:50 by martin_csr.
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
08 Feb 2012 13:03 - 08 Feb 2012 13:06
#502786
I Love my Pingal!! The slot in the bottom of the tank needs to be shaped so it will slip in. I used an acorn bit to do this with out alot of burs.
The plate mounts in the stock pets mounting holes. pingal pet can be used.
The benifit of this is no more vaccum, high level of flow.
The negative is it must be shut off every time the bike is.
dont forget to run a fule filter.
.02
84 kz 700 a1
82 kz550 ltd
Last edit: 08 Feb 2012 13:06 by ready2ryde1985.
  • camaroguy
  • camaroguy's Avatar
08 Feb 2012 19:30
#502843
I also have a pingel but since I weas repainting the tank I just used a 1in hole saw and cut the stock threaded piece out.drilled another hole about 2 inches further back and rewelded it in.only thing I dont like about mine is there is no reserve.also filled all the other holes in the bottom and drilled a hole dead center of top in front of cap. welded a nut on it and installed a nipple for a vent hose.
  • DaddyJama
21 Feb 2012 23:33
#505577
so what i ended up doing is drilling a new hole on the other side. I used blind nut rivets to have something for the scres to get into. then i used my dremel with a metal bit to make the oblong hole in the middle..bolts up perfectly...
now i'm trying to find a 16mm cap thread to plug up the other hole and so far to no avail.. i bought a welder, i may get ambitouse and weld a nut into it..
we will see.
