81 KZ550 LTD Custom Levers and Master Cylinder Opt
  • Johnny NoPants
  • Johnny NoPants's Avatar Topic Author
01 Feb 2012 13:20
#501313
I have a 1981 KZ550 LTD that I have been fixing up. Bought it not running, and am ordering some "cosmetic" parts. I found these on eBay, and wanted to know if they would be ideal for this bike, running single front disc brakes.
Motorcycle Clutch Brake Levers Set 7/8 Black Handlebars #753
Anyone have some insight? I don't want to order them if they will not work for my setup.
Also, anyone have any suggestions for new master cylinder, lever sets? I am looking for Black, NON-Stock, with NO mirror mount on the brake side (Mirror mount on clutch side used for GPS mount).
Johnny NoPants
1981 KZ550 LTD
  • Jdee
  • Jdee's Avatar
Re: 81 KZ550 LTD Custom Levers and Master Cylinder Opt
02 Feb 2012 16:11
#501558
Hey,
I'm working on an '82 KZ550. Luckily, mine is running. I've been looking into a new lever setup similar to what you are looking at.
The best input I have with it would be what type of bars you want to put on it. The stock mounts for an '81 and '82 are the same meaning the bars would need to be 7/8" at the mount at least. So, these should work fine with the setup you're looking to go for.
And I'm confused with your second question? Are you looking to get this and get a different master cylinder than comes with it? That shouldn't be too hard but would most likely mean a different mount separate from the one provided. But, it looks like it should work well and I think I might get a set myself.
  • Johnny NoPants
07 Feb 2012 13:03
#502565
Well, I ordered that set, and got an email from the seller about them being on a holiday. They will ship some time next week.
I was just looking for a nice matched set to put on my rebuild. Frame, wheels, tank, side covers, and fenders are at the media blaster for cleanup and paint right now. I will post some pics soon of the rebuild process.
Johnny NoPants
1981 KZ550 LTD
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
07 Feb 2012 13:53
#502576
I have been looking at these also if you have good results please post pics and info!!!
I have email and mesaged them and got no info I have 7/8 bars but I also have duel front brakes.
Things like piston diamter and mabe the banjo bolt size would be nice..
Thanks in advance ...
84 kz 700 a1
82 kz550 ltd
  • Roca
  • Roca's Avatar
02 Mar 2012 02:28
#507337
I'm looking at the same set! Mine are for a 1980 kz550 single disc setup. Let me know how well they work.
1980 KZ550-C2 LTD Custom
  • DaddyJama
  • DaddyJama's Avatar
02 Mar 2012 10:15
#507354
Does it come with the master cylinder too? And clutch perch?
2005 636 - track bike
1982 kz440ltd - new toy;)
  • Johnny NoPants
02 Mar 2012 12:27 - 02 Mar 2012 12:29
#507374
I got the bike put back together and running, and have these installed. They are perfect! CNC Machined aluminum handles, and cast aluminum perchs. Master cylinder is sufficient for single rotor setup; works great on mine. They also have 6 adjustable positions for lever pull. I use mine on 1, and have no issues with braking or clutch pull. I have superbike bars on my KZ, and the master cylinder mounts next to the stock throttle housing with no issues. I do think I will need a shorter brake line coming out of the master cylinder. I will snap some pics and post them tonight.
@DaddyJama, Yes, this is a master cylinder and clutch perch handle kit
Overall impression:
Function - 10/10
Style - 10/10
Price - 9/10
Johnny NoPants
1981 KZ550 LTD
Last edit: 02 Mar 2012 12:29 by Johnny NoPants.
  • Johnny NoPants
02 Mar 2012 22:28
#507486
The front view
Attachment uploadfromtaptalk1330737955188.jpg not found
The master cylinder
Attachment uploadfromtaptalk1330738034657.jpg not found
The clutch
Attachment uploadfromtaptalk1330738095247.jpg not found
Johnny NoPants
1981 KZ550 LTD
  • Roca
  • Roca's Avatar
03 Mar 2012 01:30
#507509
Nice! I can't wait to get mine!
  • DaddyJama
06 Mar 2012 23:30
#508220
Yep. I'm going to order as well.. Way did u do for brake lines?
  • djplatinum50
  • djplatinum50's Avatar
13 Mar 2012 12:06
#509404
Hey I have a 1980 550LTD that Im working on. Im really digging your bike. do you have a build thread or any other picture of your bike, i.e. how you mounted the rear fender etc.
Thanks,
Tom
1980 Kawasaki KZ550C1 LTD
  • Johnny NoPants
13 Mar 2012 12:25
#509407
@DaddyJama - I used the brake lines that were on the bike from the PO. They were braided steel, and the right length.
@djplatinum50 - I chopped the original fender down, and bent it at a 90 degree angle to accommodate the new Brake/Tail/Turn signal assembly.
Johnny NoPants
1981 KZ550 LTD
The following user(s) said Thank You: DaddyJama
