Swingarm identification question.
- carolinaboy
31 Jan 2012 23:50
Hey guys. I was wondering if I could get some help identifying this swingarm. I have 3 swingarms here in my parts pile. This is the one that came freshly powdercoated, so I'd rather use this one.
The needle bearings were removed for powdercoat. I believe it to be a KZ1000 swingarm. I'm thinking it is from a model that uses only 1 bearing per side. I just want to be certain before ordering new bearings.
If it helps, the number 607 is stamped on the swingarm. It is the only marking to speak of.
Re: Swingarm identification question.
01 Feb 2012 00:03
To me it looks like my KZ650-C1 swingarm. My swingarm does not use bearings, it uses bushings. Here's mine:
Attachment KZ650-C1SwingarmPic.jpg not found
- carolinaboy
01 Feb 2012 00:23 - 01 Feb 2012 00:40
Could be, I suppose. The overall length is 22" if that helps at all. 9" wide at the tube.
Last edit: 01 Feb 2012 00:40 by carolinaboy.
- bluej58
01 Feb 2012 20:23carolinaboy wrote: Could be, I suppose. The overall length is 22" if that helps at all. 9" wide at the tube.
That's what my swing arm measures and I've got a 78 kz1000.
also my chain guard bracket matches what you have.
To me it looks like you have the single bearing type.
Make sure you have the right sleeve for it.
JD
78 KZ1000 A2A
- Jeff.Saunders
01 Feb 2012 22:34
The numbers are a date code
6 is 1976
07 is July
The curly bracket holds a brake hose - so it's a disk rear end.
So it would likely have been used on an early 77 model built in the August/September 1976 time frame
6 is 1976
07 is July
