Gearing Change with rim size change Questions
  • kzcafe750_24
  • kzcafe750_24's Avatar Topic Author
31 Jan 2012 01:56
#501034
Hey guys,
Have 81 kz 750-4 stock gearing(13/32-630 chain). I'm going to to change the the sprocket and chain to a 530(16/39) and swapping the stock 16in rim with a 18in rim; and I am just wonder how changing the rim size will affect my gearing for stock? Any info would be great.
Thanks,
Dylon
I am planning to put a 530 chain on with a 17 tooth front and 44 tooth rear sprocket.
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985 Honda Magna 500 (Stock)
1994 Honda XR200R (Built)
Re: Gearing Change with rim size change Questions
31 Jan 2012 02:02 - 31 Jan 2012 02:36
#501035
kzcafe750_24 wrote: ... swapping the stock 16in rim with a 18in rim; and I am just wonder how changing the rim size will affect my gearing for stock?....
If tires have equal outside diameters, the gear ratio won't change due to difference in wheel diameters.
Good Fortune! :)
Last edit: 31 Jan 2012 02:36 by Patton.
  • ramtough_63
  • ramtough_63's Avatar
31 Jan 2012 02:03
#501036
depending on the height of the tire. there is a calculation for tire sizt that will give you the overall hetgth with your 16 inch rim then useth the calculation for the 18 inch rim to see which tire is actually 2" shorter I cant remember the exact calculation
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
31 Jan 2012 02:24
#501037
here is the calculation
Tire size lets say 130
times the aspect ratio
lats say .90
130X.90= 117
devided by 25.4 (metric conversion)
=4.6 inches
plus your current rim 16
=20.6 is you current tire height
130X.90/25.4+16=20.6
130X.55=71.5/25.4=2.81+18=20.8
you can use this with any width as long as they make a tire to keep you heght the same
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
31 Jan 2012 10:06
#501062
The stock gearing on the 1981 KZ750 E2 (which came standard with an 18" rear wheel running a 400H-18 tire) is 13/33. That's not much different than what you have today; probably because of the rear tire diameters being pretty close. Ed
  • testarossa
  • testarossa's Avatar
31 Jan 2012 13:42
#501087
Use this website: www.gearingcommander.com/
You can plug in different tire sizes, and gear combinations. It will tell you more information than you want to know about rpms per given speed, chain wear calculations, etc.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
