School me on braided brake lines
  • casper3043
  • casper3043's Avatar
Re: School me on braided brake lines
05 Apr 2012 22:39 - 05 Apr 2012 22:40
#514279
mark1122 wrote: ok, now u have me confused. easy to do :P .
the pic u posted showed that u had dual front brakes ?
u can put 1 or 2 lines on a master. u just use a dif bolt. if u use 1 line from master to a cal, u would jump from 1 cal to a second cal with another line. i thought u had dual front brakes ?
i personally feel that using the slitter, keeps the lines neater and easier to keep out of harms way.
please explain how u r routing the lines?
the pic isn't my exact bike, just the same caliper. my kz650 (77) has a single caliper.
i plan on routing the one line behind the forks (just like oem). i just need to verify fittings for the MC and caliper, that's all.
Last edit: 05 Apr 2012 22:40 by casper3043.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Apr 2012 11:05
#514346
ok, i see.
when u get your clip ons u can mount the master and see how it looks.
i did find this
www.cyclebrakes.com/GalferFittings05.pdf
maybe u can just call and get advice on the bottom fitting. email them the pic of the cal and see what they have to say.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • casper3043
06 Apr 2012 13:15
#514392
mark1122 wrote: ok, i see.
i did find this
this is where i'm ordering the lines from. i did call and talk to someone at cyclebrakes, but the woman taking my order couldn't confirm anything; just place the order. and if i mess it up, it's on me.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Apr 2012 16:37
#514422
r u ordering clear silver lines?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • casper3043
06 Apr 2012 21:08
#514465
mark1122 wrote: r u ordering clear silver lines?
probably...but i don't plan on making my own if that's where you're going with that question.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 Apr 2012 10:46 - 08 Apr 2012 10:59
#514690
the only tricky part i see for u is the cal end. the master will be simple.
the calipers sealing surface is recessed, so a banjo will only want to fit into that recess from the side. a 90* banjo would work but it would exit to the side before turning upwards.
i'm not sure a banjo would even seal properly against that surface , since it may not even be a machined surface?
if u got a threaded end like the stock 1, it would likely be the best way to go.
ask Galfer if the 019c fitting in this catalog (forth page, pg 301)would be appropriate for your application.all u need to know is if it is the right thread or if u would need an adapter to make it work. it looks like a perfect fitting for your application. it says 10mm. but its a female end. u would need a male adaptor fitting.maybe #7a or #7D on pg 305?or 732A on pg 309 ?
Have u tried the 650 forums? heres a couple.
forums.kz650.info/
www.customfighters.com/forums/showthread.php?t=31630
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 08 Apr 2012 10:59 by mark1122.
  • casper3043
09 Apr 2012 03:32
#514804
i think i'll go with a 12 degree bend banjo on the MC to route the line to the clutch side caliper.
as for the caliper, you're right...its a bit tricky. i think galfers 728c is what i would need (10mm) and its a male fitting. i'll try contacting galfer again and hope they don't transfer me elsewhere again.
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
09 Apr 2012 12:01
#514836
Good thread RamTough. Been needing to do some lines on a couple of my bikes and this has gotten me sparked up.
First bike needs the lines shortened a couple inches and new fittings installed.
I'm wondering if I want to invest in crimp tools or go with screw on fittings?
I wouldn't mind having the tools to build lines for other bikes, just haven't pursued the cost of it all yet.
This is what happens when lines that are too long are used, check oil cooler:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
