School me on braided brake lines
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: School me on braided brake lines
26 Jan 2012 17:51
#500216
Pm dave(OMR), he's got zx6r brakes on his with braided lines.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • MFolks
  • MFolks's Avatar
26 Jan 2012 19:18
#500230
Braided bake lines look cool, but it will act like a slow speed file on paint,fuel lines, electrical cables & other brake lines if it's not got a protective covering on it.
Radio shack sells a black spiral wrap that will fit brake lines, I believe it's 1/4", but will expand to fit larger lines.
26 Jan 2012 19:53 - 26 Jan 2012 19:53
#500238
Take a look at these (see link). They are braided stainless steel with a plastic outer layer to prevent chafing and seal out moister. Oh, and they come in different colors. Ed
www.cyclebrakes.com/html/galfer_brake_lines.html
Last edit: 26 Jan 2012 19:53 by 650ed.
  • bluej58
  • bluej58's Avatar
26 Jan 2012 20:25 - 26 Jan 2012 20:26
#500242
Those look sharp.
Just in time, I tried to buy some lines over the phone today and the guy told me to just take my old lines in to some one and have them match them up.
Which ain't a bad idea.
but I may have to rethink this .
78 KZ1000 A2A
Last edit: 26 Jan 2012 20:26 by bluej58.
  • ramtough_63
  • ramtough_63's Avatar Topic Author
26 Jan 2012 21:15
#500245
Thanks guys I appreciate the help. I am a little more knowledgable bout the differences in the different lines and fittings for my application.
3-AN fitting will fit most -3AN Lines. mixing brands isn't as big of an issue
and of course the zx is a 10mm fitting with a 10mm x1.25 pitch banjo bolt
I ordered mine for the back yesterday
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • casper3043
  • casper3043's Avatar
05 Apr 2012 02:38
#514136
650ed wrote: Take a look at these (see link). They are braided stainless steel with a plastic outer layer to prevent chafing and seal out moister. Oh, and they come in different colors. Ed
i've been having a hard time to get an answer on the fittings needed to convert the stock lines on a 77 kz650 to a single line.
banjo at master cylinder 10mm x 1.25
0 degree or 12 degree banjo at master cylinder?
35 inches in line length from master cylinder to caliper
90 degree male fitting (10mm) at the caliper (galfer fk728c)?
i don't want to get the fittings wrong since they're custom ordered...any feedback would be appreciated
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Apr 2012 17:52 - 05 Apr 2012 17:57
#514222
why is it so difficult to look at the lines u have and figure out what bend u need? i dont mean to sound nasty, just trying to understand the issue? i have done several , and there is no magic formula. just look at what u have and determine what u need.
u can also order universal Russell lines from Z1E.(unless u want a custom color) u order hose to length, and ends. then u screw the ends on when u get them. if u make a mistake , u order a new end only. this is very simple u will be fine.
Perhaps, if u posted a pic,of master and cal, we could be more helpful?.
ps. make sure the forks r fully extended when measureing line lengths.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Apr 2012 17:57 by mark1122.
  • casper3043
05 Apr 2012 18:09
#514227
thanks mark...
this is my MC
www.dimecitycycles.com/vintage-caferacer...ver-kit-17-653b.html
and this is the front brake caliper
kawtriple.com/tripleed/webpage7/361l.jpg
the reason it may be difficult for me, and maybe i'm over thinking it, is because there are several options for banjo fittings (at least with the MC). i believe i can run a 0 degree or a 12 degree. what the difference would be, i don't know. so if someone already had the fittings tested, that would solve any questions i would have.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Apr 2012 18:41 - 05 Apr 2012 18:44
#514230
we would need to see a pic of the master mounted. but if no one has the info u need, just mount it . then decide how u want the lines to run. u dont have to follow the original path. its what ever u like best. realistically, a straight or 12* aren’t that dif, i dought that it could cause an issue unless u had some obstruction..
as for the caliper. Im wondering if a 45* may be best. Unless there is no room at the base for a 45 to turn up and back,(it may need to turn up and out due to the U shape, around the current line) unobstructed, I think it would work.
I don’t see u using a 90* there.
Do u have an old line u could play with to figure it out ? if not, maybe u could order 1 straight end from Z1E and see how it fits.
I imagine that u will be using straight fittings at the splitter?
What do u think about using the Russell do it your self lines ?
just a thought. maybe u should start a new thread with the bike type in the title. maybe u will get more interest from like riders. u could copy and past this stuff into it ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Apr 2012 18:44 by mark1122.
  • casper3043
05 Apr 2012 20:49
#514248
mark1122 wrote: we would need to see a pic of the master mounted. but if no one has the info u need, just mount it . then decide how u want the lines to run. u dont have to follow the original path. its what ever u like best. realistically, a straight or 12* aren’t that dif, i dought that it could cause an issue unless u had some obstruction..
my clip-on's are on backorder so i can't mount the MC yet.
i don't understand your 45* banjo theory. i plan on replacing the rubber stock lines and hard line with a stainless one (bypassing the splitter) since the MC is wired for one. i've posted on several boards to no avail. all i need is 1 dude to chime in on a single brake line setup so i can get the correct fittings at the MC and caliper.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Apr 2012 21:12 - 05 Apr 2012 21:14
#514252
ok, now u have me confused. easy to do :P .
the pic u posted showed that u had dual front brakes ?
u can put 1 or 2 lines on a master. u just use a dif bolt. if u use 1 line from master to a cal, u would jump from 1 cal to a second cal with another line. i thought u had dual front brakes ?
i personally feel that using the slitter, keeps the lines neater and easier to keep out of harms way.
please explain how u r routing the lines?
Attachment spiegler_brake_line_routing.jpg not found
Attachment duallineatmaster.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Apr 2012 21:14 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Apr 2012 21:27
#514257
just thought of something else.
if u didnt like routing the lines to the cals in front of the forks, u could move the cals back, behind the forks.
i just traded the right and left forks around on mu kz back in the 80's.
this is what i got.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
