Changing to a 530 chain. Ratio?
- Wizzard
24 May 2006 11:17
Im changing to a 530 chain on my KZ 1000 stock was 15-33-630 Im changing to 16-42-530 I found this folowing info on another post.
multiple all the 630 numbers by 1.2 - 630 chain is 3/4", 530 chain is 5/8"
15T front becomes 18T
33T rear becomes 39.6T (or 40T)
92 link chain becomes 110.4 (or 110 links).
The key question is; are you happy with the stock gearing? Stock on the
KZ1000-A1
is 2.20:1 ratio (33 divided by 15).
So mine is a 2.20:1 ratio stock with the 530 set up the new ratio will be 2.625:1. Will this ratio be to much of a diference I do want more take off not woried about topend but still want it to be streetable. The gears I can get from local bike shop are 16t and 17t front sprocket and 38t,42t,44t,46t should I go with a different set up??
Also the sprockets are going to be 54.00 for rear
35.00 for front
134.00 110 link
green chain
all these prices are in canadain prices are these good or bad prices??
Thanks for any info or ideas
WIZZARD
KZ1000-A1
35.00 for front
134.00 110 link
green chain
WIZZARD
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- Sleepy
Re: Changing to a 530 chain. Ratio?
24 May 2006 14:43
seems expensive. You need to shop around.
Although for my 650, I only paid $80 or so US dollars for my 530 chain, and $40 for BOTH sprockets.
not sure what that is in CDN $'s
kz650 gs750 cb750
- Wizzard
24 May 2006 15:01
Well it still doesn't equal my price. Thanks for the reply
WIZZARD
WIZZARD
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- steell
24 May 2006 15:23
$1.12 Canadian equals $1.00 US at the moment (just checked Official Exchange Rate). Then if you order from the US you have to add in shipping and Duties (really expensive if you use UPS, so don't).
- Wizzard
24 May 2006 15:43
Well I open to all ideas and make the best choice when its all done. Thanks for the reply steell.
WIZZARD
WIZZARD
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- Wizzard
25 May 2006 10:45
Well made the leap and talk to Jeff at Z1 and ordered a 530 setup 17t front and 41 rear should make a good diference. Thanks everyone and thanks Jeff!!
WIZZARD
WIZZARD
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
