What is the front Axle nut size on a kz750r1?
- Juan1
09 Jan 2012 04:25
My project of the week was going to be restoring my front wheel. Unfortunately, I lacked any wrenches large enough to remove the axle nuts for the front. Really unfortunately, I tried using an adjustable wrench and a vise grip, which didn't work. What size are these blasted front axle nuts? 26mm?
- gorack
Re: What is the front Axle nut size on a kz750r1?
09 Jan 2012 04:51
What year and model are u working on
- gorack
- Juan1
- Mcdroid
- Gone Kwackers
09 Jan 2012 08:46
27mm
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: Juan1
09 Jan 2012 10:39 - 09 Jan 2012 11:21
Vise-grips??! Did you loosen the axle holders before attacking the nuts?
BTW, if you plan to work on your bike you really should use proper tools or you may end up creating a dangerous situation. The good news is, your toolkit will not need the following :laugh: :
Attachment ToolKit.png not found
Last edit: 09 Jan 2012 11:21 by 650ed.
