Biggest front sprocket on KZ750 4 cylinder ?
  • M357.5
  • M357.5's Avatar Topic Author
  • Kwakas N' lots of em'
27 Dec 2011 18:13 - 27 Dec 2011 18:15
#494859
Hey guy's I'm about to order my sprockets for my project.
Using a 520 chain conversion on my KZ750. Smallest rear sprocket I can use on the hub is a 38 tooth, so to keep the gearing similar to stock ( 2.54 ratio with the 18" rear wheel...I'm wanting to go 2.38 ratio due to the 17" rear I'm using ) I need to go with a 16 tooth front sprocket...will the 16 tooth clear the cases ???
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 27 Dec 2011 18:15 by M357.5.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Biggest front sprocket on KZ750 4 cylinder ?
27 Dec 2011 21:07
#494885
The KZ650 uses a 530/16/41 or 2? stock.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • M357.5
27 Dec 2011 21:22
#494886
Groovy, thank you.
