Front Wheel Assembly
- badrhino
18 Dec 2011 15:05
Can someone please post a shot of the diagram for the front wheel assembly for an 1980 KZ1000 LTD or similar models. :whistle:
Thanks!
Thanks!
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- wireman
Re: Front Wheel Assembly
18 Dec 2011 15:26
what part is giving you trouble,the speedo drive still?
- badrhino
18 Dec 2011 15:33
Yes the speedo drive sleeve, just making sure it didn't have a circlip on the outside like the ones on later models.
Franken Z!
Franken Z!
- wireman
18 Dec 2011 15:38
send a pm to patton
18 Dec 2011 17:05 - 18 Dec 2011 17:10badrhino wrote: Can someone please post a shot of the diagram for the front wheel assembly for an 1980 KZ1000 LTD or similar models. :whistle: Thanks!
Here's the 1980 KZ1000 LTD diagram from kawasaki.com, and the parts listing.
[Add checked items to Pick-List] REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
[Add to Picklist: 41069-033]
1 41069-033 COLLAR,FRONT AXLE 2
[Add to Picklist: 41078-008]
2 41078-008 GEAR BOX ASSY 1 KZ1000-B3, KZ1000-B4
[Add to Picklist: 41082-001]
3 41082-001 PIN,SPRING 1
[View Supersession]
[Add to Picklist: 41063-001]
4 41063-001 WASHER THRST SPD PINI 2
[Add to Picklist: 41060-017]
5 41060-017 PINION,SPEEDOMETER 1
[Add to Picklist: 92028-1066]
6 92028-1066 BUSHING,SPEEDOMET CBL 1 KZ1000-B4, KZ1000-B3
[Add to Picklist: 41059-026]
7 41059-026 GEAR,SPEEDOMETER 1
[Add to Picklist: 92049-1057]
8 92049-1057 OIL SEAL,BJN30427-C3 1
[Add to Picklist: 41068-049]
9 41068-049 AXLE,FRONT 1
[Add to Picklist: 92001-158]
10 92001-158 BOLT 8
[Add to Picklist: 92088-023]
11 92088-023 WASHER,LOCK 4
[Add to Picklist: 41042-014]
12 41042-014 DUST COVER 1
[Add to Picklist: 41064-013]
13 41064-013 RECEIVER,GEAR 1
[Add to Picklist: 601B6203ZZ]
14 601B6203ZZ BRG,BALL,#6203ZZC3 2
[Add to Picklist: 92027-1043]
15 92027-1043 COLLAR,FR HUB BEARING 1
[View Supersession]
[Add to Picklist: 92033-1040]
16 92033-1040 RING, SNAP,43.5M/M 1
[Add to Picklist: 654A254008]
17 654A254008 OIL SEAL 1
[Add to Picklist: 41042-015]
18 41042-015 DUST COVER 1
[Add to Picklist: 41069-032]
19 41069-032 COLLAR,FRONT AXLE 1
[View Supersession]
[Add to Picklist: 41021-071]
20 41021-071 TIRE-FRONT 1
[View Supersession]
[Add to Picklist: 41022-046]
21 41022-046 TUBE 350/375/410-19 1
[View Supersession]
[Add to Picklist: 41073-1040]
22 41073-1040 SOLID WHEEL ASSY,FRNT 1
[View Supersession]
[Add to Picklist: 41075-1011]
23 41075-1011 BALANCER-WHEEL,10G AR
[View Supersession]
[Add to Picklist: 41075-1012]
24 41075-1012 BALANCER-WHEEL,20G AR
[View Supersession]
[Add to Picklist: 41075-1013]
25 41075-1013 BALANCER-WHEEL,30G
AR
Only seeing the #16 snap ring, but wouldn't bet the farm based solely on this diagram.
Last edit: 18 Dec 2011 17:10 by Patton.
18 Dec 2011 17:08
If needed for help navigating the kawasaki.com site,
click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- badrhino
18 Dec 2011 17:44
Thanks Patton, disregard pm sent to you.
Franken Z!
Franken Z!
18 Dec 2011 18:34
If it might be helpful, here's a copy from the FSM covering '77~79 KZ1000-A models, which all look very similar on the various kawasaki.com diagrams.
- badrhino
19 Dec 2011 02:26 - 19 Dec 2011 02:28
I was pretty much just wanting to know what all held the speedo drive (sleeve) on and as the diagrams and pic show it is just sitting inside the wheel cap that covers the disc rotor. That is how I put it back together but was just wanting to make sure.
Thanks
Thanks
Franken Z!
Franken Z!
Last edit: 19 Dec 2011 02:28 by badrhino.
- z1kzonly
19 Dec 2011 02:45
That's it. it just sits there under that 4 bolt hole, chrome cover that covers the disc.
The axle holds em in place.
- z1kzonly
19 Dec 2011 02:49I just sold a spoke wheel set up on ebay that was similar!
Here is the pics.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=110785659345
