kz1000 frame selection
- Sambow614
16 Dec 2011 10:21
Currently in the process of finding the right frame and motor to start a full restoration. There is a 79 or 80 (not sure) kz1000csr I found pretty cheap but the frame looks different from the other projects I've seen. My question (for now) is: what is the best year or model frame to start with or in other words, is there any advantage to a particular frame design of a certain year or model kz 1000. I plan to do many mods to motor, front and rear end swap but keep dual shock.
Any answers to this would be much appreciated. thanks guys
77 kz1000 / zx10
The following user(s) said Thank You: Samminorwich
- roy-b-boy-b
Re: kz1000 frame selection
16 Dec 2011 10:52
I would look for a KZ 1000 from 1977 to 1980. Even a 1976 KZ900.
It doesn't matter wheather it is a LTD or standard. Most parts will bolt on. Roy
16 Dec 2011 10:56
If interested, zedder can identify/confirm: (1) the motor year from the engine serial number; and (2) the frame year from the vehicle identification number.
- etbike3135
16 Dec 2011 11:03
Not sure if you have a bike or parts already to start with? A CSR 1000 is a 81 or 82 and has a different engine then a 73-80 (no kick start for one thing). However if I could go back in time and do everything all over again I would use a 81 up 1000 or 1100 for a build. The frames were better along with the brakes and suspension. Oh, and the motors were way more powerful stock then anything earlier. Now a days they are cheaper too because they don’t have the "collectability" factor the early bikes do. I would think with some searching you could find one for about $600 with a title.
1973 Kawasaki Z1
18 years in dragbikes
- z1kzonly
16 Dec 2011 13:02Sambow614 wrote: Currently in the process of finding the right frame and motor to start a full restoration. There is a 79 or 80 (not sure) kz1000csr I found pretty cheap but the frame looks different from the other projects I've seen. My question (for now) is: what is the best year or model frame to start with or in other words, is there any advantage to a particular frame design of a certain year or model kz 1000. I plan to do many mods to motor, front and rear end swap but keep dual shock.
Do you want dragbike-pro-street look, bar hopper?
Or highway twisty road race look?
I have a stock 1976 KZ900 frame with title.
And a 1977-8 kz1000 raked out with rectagal. strut swingarm I am fininishg up.
Stuff is for sale in Buffalo , NY Area
Attachment 1frame.JPG not found
Attachment salenow.JPG not found
- Sambow614
16 Dec 2011 19:26
Thanks a lot for the info, definitely need the kick start so I will look for an older model motor. as for the frame, you are probly right about them being better (stronger) than the 79s but there is a spot by the steering stem right in front of the gas tank that looks cobbled up on all the frames i look at. However in the photos i see of some restored on this sight, the frame tubes are beautifully attached to the steer tube/stem. I guess I cant tell if thats factory or fabbed up. Any thoughts?
77 kz1000 / zx10
- Sambow614
16 Dec 2011 19:30
is that the frame you are selling in the first pic? How much? I really like the swing arm conversion.
77 kz1000 / zx10
- z1kzonly
19 Dec 2011 02:15
Hey, sorry for the delay. I was out of town for a couple of days.
I got rid of that Suzuki swing arm and shock deal 12 days ago on ebay. That frame is a stock 76 KZ900 with Ohio Title. It is powdercoated. I am puting the stock swingarm and frontend together with it. And a set of wheels. I want a $1000 for all the parts that I can come up with. lower end of engie. Have a seat, tail piece, 2 chrome fenders, wiring harness, stock air box, nice frt. master cylinder, nice complete back wheel assembly.
Attachment sale44.JPG not found
- Samminorwich
02 Nov 2021 09:46
I am in sure this frame is not a kz1000A
can anyone help.please
02 Nov 2021 16:59
Looks like a 1978 Kz1000A
02 Nov 2021 17:52You can check the frame number here.I am in sure this frame is not a kz1000A
www.kzrider.com/filebase?task=download.s...id=1178&catid=64&m=0
- z1kzonly
02 Nov 2021 18:02Looks like a 1978 Kz1000A
Wow! A 10 yr. old thread! I see some of my old stuff! I wish I had those items back! I gave that stuff away 10 yrs. ago!
But yes a 1978 frame. Those rear brackets for mufflers filled with water and rusted quick. Kaw factory switched back on the LTD 79-80 frames.
