What Chain to use?
- ramtough_63
What Chain to use?
14 Dec 2011 21:08
ok I ordered a 40T 520 rear sprocket today plan on using a 18t offset for the front with a zx6 17" wheel with a 190/55 tire
How many link chain Should I order? is there any brands to stay away from?
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- bountyhunter
Re: What Chain to use?
14 Dec 2011 21:14
I get chains and sprockets from Z1. They sell a very good X ring chain for the cheapest price I have seen.
- Fritula
- holly land garage
22 Dec 2011 06:04
ramtough hope you will find front offset sprocket for 520.I am looking for one too.The reason I choose 520, because everyone with rear wheel upgrade have chain/frame clearance trouble.I am not there yet ,but it looks,I should pay a visit to machine shop in the future.
- jonnybravo
- Banned
22 Dec 2011 06:07
is ti a custom swings are ??? if not measure what u got, if it is a custom, add a few link and get a master,
- TeK9iNe
- What did you do!?!
22 Dec 2011 12:22ramtough_63 wrote: ok I ordered a 40T 520 rear sprocket today plan on using a 18t offset for the front with a zx6 17" wheel with a 190/55 tire
Sweeeet
+1 on the Z1 info -they are the best.
You can measure with a quick homemade jig. Once you have your sprockets (or know the diameter from the oem), cut 2 discs of cardboard same sizes. Then place them in the correct orientation on the bike (tightest position) and run a string around them like a chain.
520 Chain is 5/8ths inch pin to pin and 1/4inch wide.
Mark every 5/8ths around the string till you get to the beginning. Add 1 link.
Good luck.
Check here for more info: www.z1enterprises.com/reference/chaintypesize.aspx
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
22 Dec 2011 15:23 - 22 Dec 2011 15:26
Am thinking 530 @ 3
/8
" width reduced to 520 @ 2
/8
" width gains 1
/16
" space between chain and tire sidewall.
Comparing same size chain, non-o'ring chain should be slightly thinner.
Last edit: 22 Dec 2011 15:26 by Patton.
