Stearing stem rake on zx front end conversion???
Re: Stearing stem rake on zx front end conversion???
22 Dec 2011 12:01
those are nice triples.
i believe that they adjust the trail and not the rake tho.
- 893cv
22 Dec 2011 16:11
All Balls can help you with the bearings you will need for your project.
www.allballsracing.com/
Use the "Find Fork Conversion Bearings" area and you will get the information you need.
werkingman wrote: i read and reread these post and i see nothing about the bearings on a swap help me out u guys im putting 85-6-7 frontend on my 81 kz and i would like some help on the bearing swap or advice or even some of you out there that may have done i plan on swapping front and rear from same donor to same KZ HELP!! thanks in advance
1980 kz1000 LTD
1978 Z1R
1978 Z1R
