help steering bearings and races
- vintsham72
10 Dec 2011 13:33 - 10 Dec 2011 13:34
kz1000 '78 A2A
I bought all balls tapered bearings back in april 2011. installed the races but messed up the lower bearing. the roller cage was black and a little taller than the replacement I received which has a different design silver with a lower roller cage. I guess they changed the design but same measurements. my question is do I need to replace the races with this new kit? like I said same all balls part number 22-1014 but a new design.
also I have a kz1000 a2a with original steering ball bearings. I notice with my other bike and new taperd bearings there is a slight difference in height meaning the lower stem and upper tree should compress just a little more
Last edit: 10 Dec 2011 13:34 by vintsham72.
- wireman
Re: help steering bearings and races
10 Dec 2011 13:45
id use the race that comes with the new bearing
- Mcdroid
- Gone Kwackers
10 Dec 2011 14:19wireman wrote: id use the race that comes with the new bearing
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- vintsham72
10 Dec 2011 14:38
any advice on taking out these tapered races? they are in flush
10 Dec 2011 15:00 - 10 Dec 2011 15:01
If there is no edge showing on the inner circumference you won't be able to drive them out with a drift pin. You may need to use a Dremel tool with a cutter or small grinding attachment to cut the race. If you do, take your time so you don't damage the steering stem. Ed
Last edit: 10 Dec 2011 15:01 by 650ed.
- vintsham72
10 Dec 2011 15:03
is this tottaly necessary. I mean with the new set of bearings and having to take out these races?
10 Dec 2011 15:17vintsham72 wrote: is this tottaly necessary. I mean with the new set of bearings and having to take out these races?
You may want to contact All Balls about this. When I installed mine I wasn't sure whether they should be torqued to the factory spec since they were a different type of bearing than the original, so I called All Balls to ask. I found them very friendly and helpful (the answer was yes - use original factory torque spec). I believe their toll free number is 888-228-3323; they're in PA. Ed
- Tony
Author
- Kapahulu
12 Dec 2011 00:50
Vintsham,
When you get the answer please update this post for the rest of us KZ1000 owners.
2strokeworld.com
2strokeworld.com
- DiamondSkyBlue1000
12 Dec 2011 01:33
I have the same kit and am about to start this project as well.
Any info and pictures would be greatly appreciated!
- wireman
12 Dec 2011 01:58you should only have one race to knock back out,bottem of steering headvintsham72 wrote: is this tottaly necessary. I mean with the new set of bearings and having to take out these races?
- werkingman
20 Dec 2011 04:15
im putting 86 zx front on my kz750 and i have no idea as to what bearing change i need you smart fukers gimme a hand
