KZ650 and KZ550 wheels swap
- JCM
02 Dec 2011 15:25
Is it possible to replace 1979 KZ650SR rear 16" and front 19" wheels with 1980s KZ 5-star 18" rear and 19" front wheels? What would it require? Thanks
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: KZ650 and KZ550 wheels swap
02 Dec 2011 22:03
You already have a 19" wheel on the front now and IIRC the SR model front wheel is slightly wider than the mag wheel that came on a 650C or 650F model. As for the rear the easiest thing to do is just to swap the 18" rear wheel off a 650 C model. I have a spare wheel from a 650C model if you need it. Yu might be able to use the rear wheel from an 80's model but the front is going to be a bit of a problem since they used a leading axle design and the axle is a different size than what you have now and will not fit your front end without changing wheel bearings. Hope this answers your question.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- JCM
03 Dec 2011 01:40
Thank you. this is helpful. I like the look of the 5 star mags a little more but worry that even if I swapped bearings and used an axle, sprocket, etc. from the 550 wheel I might encounter width issues and break alignment and sprocket issues. My main objective is to put an 18 in the rear rather than keep the 16 so the 650 C idea is probably the best route.
- loudhvx
04 Dec 2011 02:14
5-spoke, or 7 spoke?
I think only the 82 and 83 KZ550H (gpz550) had 5 spoke wheels (18 rear, 19 front). The rest had 7-spoke. 19 front, and 18 or 16 rear.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
