front fork ??
  • j236racing
  • j236racing's Avatar Topic Author
front fork ??
27 Nov 2011 03:40
#490296
Im attempting to run a 88 honda hurricane front end and was wondering if anyone has messed with one of these before? It has air valves at the top of the tubes, I put new seals and oil in them and they dont have much travel and dont rebound very well? Im running the spec amount of oil and air, and I can pull the forks down by hand and bottom them out? Any tips? thanks
Lifes a garden, DIG IT!!!
  • testarossa
  • testarossa's Avatar
Re: front fork ??
27 Nov 2011 04:26
#490302
How much air pressure do you currently have in the forks? Do you know what the spec is from Honda for the original application? I would guess that a 1988 Hurricane is at least comparable to a Z1/KZ900/KZ1000 for weight, if maybe slightly lighter, but not much.
Too much air pressure might counteract the springs and make the fork perform as you have described. Unfortunately, I have no specific experience with this front end. I do own a 1982 CB750F with an air over oil fork that calls for 11-17 psi air pressure. No clue if that is even remotely similar to a Hurricane that is six model years newer.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: front fork ??
27 Nov 2011 12:50 - 27 Nov 2011 12:58
#490330
it doesnt seem right. the springs alone should supply a lot more resistance than that.
maybe try and google a Huricane forum for some help.
heres 1
cbrforum.com/forum/cbr-1000f-hurricane-38/
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 27 Nov 2011 12:58 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: front fork ??
27 Nov 2011 12:53 - 27 Nov 2011 12:58
#490332
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • j236racing
Re: front fork ??
27 Nov 2011 18:36
#490396
Hey thanks alot guys, that manual helps!! much appreiciated!!
