Rear master cylinder rebuild kit ???
- kenthewrench
- RIDE IT LIKE YOU RENTED IT!!!!!!!!!!!
26 Nov 2011 13:15
Having a hard time finding a rebuild kit for my 1980 KZ1000E(shaft) model. Does anyone know of another model that has the same rear M/C ?? K&L and Sudco don't have listings for the rear. Thanks====Ken
Re: Rear master cylinder rebuild kit ???
26 Nov 2011 13:59
According to kawasaki.com, the piston assembly and primary cup are shared on several models.
Piston 43072-004
Model (19):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ1000-C2 (Police 1000) (1979)
KZ1000-D1 (Z1R) (1978)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-B1 (LTD) (1976)
Primary cup 43019-002
Model (22):
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Piston 43072-004
Model (19):
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
Model (22):
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
26 Nov 2011 14:02
26 Nov 2011 14:05 - 26 Nov 2011 14:09
Unless cups are torn, master cylinders may often be restored to serviceable condition with the existing parts.
But a new cir-clip may be necessary.
According to kawasaki.com, the piston, primary cup, and dust cover are shown as active parts, meaning they should be available through Kawasaki dealerships.
Last edit: 26 Nov 2011 14:09 by Patton.
- kenthewrench
26 Nov 2011 14:39
Thanks for the info Patton. So I should be able to order a kit under one of the other models and I would think the same parts would be in it correct ??
- kenthewrench
26 Nov 2011 14:46
Don't know the extent of damage/wear yet. Its leaking out of the boot,which tells me "past the piston and seal".
26 Nov 2011 23:07
Dis-assembly and cleaning, along with "dressing" the bore, might eliminate the leak, depending on condition of the cups.
If the bore is pitted too badly, even new cups may not prevent leaking.
Surprisingly enough, some pitting in the bore seems to be okay.
- kenthewrench
27 Nov 2011 12:48
Thanks I'm gonna tear into it tomorrow and see. Are the boot and snap ring still available also ?? Thanks====Ken
27 Nov 2011 13:48 - 27 Nov 2011 13:50
kawasaki.com shows most all the needed parts as being still Active.
Anybody can do it, and it's usually very helpful to learn about using kawasaki.com with its good parts diagrams, part numbers, availability, shared use among models, etc.
Click here > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
There are also a few other sites with good parts diagrams.
Last edit: 27 Nov 2011 13:50 by Patton.
- Kjack90
27 Nov 2011 18:05 - 27 Nov 2011 18:07
I had a similar problem with mine. I was unable to locate a replacement piston assembly or any dealer parts other then the reservoir, and cap.
you have the mc mounted up on the frame with a long push rod correct.
What I ended up doing on mine was a member on here had a salvageable non leaking unit that I bought.
I know that Z1 enterprises does not have any seals for the 1980 kz1000e2 shaft style master cylinder. All I could find for mine was rebuilds for the 78 and before with the reservoir on the mc and the 81 and after style with the very short push rod.
the mc that your bike has is the same as the kz1000 a4. at least that is what I found when redoing the the one on my kz1000e2 shaft
www.kawasakiepc.com/SystemSearch_Frames....252&CFTOKEN=51065438
that is the mc your bike should have.
part4 along with the body on mine was bad.
I would try a good cleaning then testing to see if it leaks. again.
1980 kz1000e2 shaft returned to factory airbox, with delkevic 4-1.
1982 xj650 bobber
2005 Suzuki Bandit gsf1200s
1982 xj650 bobber
Last edit: 27 Nov 2011 18:07 by Kjack90.
