1981 kz650 gas tank
  • krosa1
  • krosa1's Avatar Topic Author
1981 kz650 gas tank
21 Nov 2011 22:57
#489601
Will any other year or models gas tank fit a 1981 kz650 without modification.
  • martin_csr
  • martin_csr's Avatar
Re: -
22 Nov 2011 01:15 - 18 Feb 2013 18:23
#489637
Last edit: 18 Feb 2013 18:23 by martin_csr.
Re: 1981 kz650 gas tank
22 Nov 2011 09:58
#489680
krosa1 wrote: Will any other year or models gas tank fit a 1981 kz650 without modification.
What model KZ650 do you have? Ed
  • H1Vindicator
  • H1Vindicator's Avatar
22 Nov 2011 10:01 - 22 Jan 2013 00:43
#489681
Last edit: 22 Jan 2013 00:43 by H1Vindicator.
  • krosa1
22 Nov 2011 22:46
#489770
Thanks for the reply. Yea i am interested in the tank. How much? Any rust, leaks?
  • martin_csr
Re: -
23 Nov 2011 10:05 - 18 Feb 2013 18:23
#489817
  • krosa1
27 Nov 2011 21:54
#490435
I just finally got the bike and it looks like it's been sitting in the bottom of the ocean. I am going to try and get it running next weekend. If it seems like it has compression I will definitely want to get the tank from you. If you sell it first no big deal I will let you know as soon as I can. And to the other guys yes it's a CSR.
  • gengomerpyle
  • gengomerpyle's Avatar
27 Nov 2011 21:58
#490436
paint job looks great
martin_csr wrote: There isn't any rust & it does not leak. I had repainted it w Duplicolor green, but it wasn't fuel proof. Other than the ugly paint & the small dings, it's a solid tank. All of the screw & bolt holes are fine. (note: there isn't a fuel cap or other stuff - I put it on the tank I'm using). I have it listed in the want ads for $30 along w a bunch of other items here -->> KZ650 CSR & KZ750 Ltd stuff
I should be able to get a current pic, but here's a photo of it prior to putting it to use. 1981 KZ650-CSR fuel tank:
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
