How to adjust the odometer?
  • Kapahulu
  • Kapahulu's Avatar Topic Author
21 Nov 2011 15:44
#489499
My odometer shows less mileage than the title. Apparently the speedometer/odometer is not original.
Can I "up" the mileage on the odometer by hooking the cable up to a drill or something like that? Reason: If I should happen to sell the bike, it makes things complicated going to the DMV with a title that shows more miles than the odometer. In Hawaii we have vehicle safety inspections with the mileage is noted. The safety inspection certificate must be presented when the title is transferred.
Thanks, Mike
2strokeworld.com
  • MFolks
  • MFolks's Avatar
Re: How to adjust the odometer?
21 Nov 2011 16:36
#489506
I suppose you could get an electric drill and run the miles up by spinning the cable(if your bike has the cable driven speedometer). Some Kawasaki's had an electric speedometer using sensors, making this job a lot harder.
  • Kapahulu
21 Nov 2011 18:59
#489524
It's cable driven, just wondering if that method will work.
2strokeworld.com
  • porchev914
  • porchev914's Avatar
21 Nov 2011 19:42
#489537
It sure will. I've done it before, but I used a dremel. It takes a little while, depending on how many miles you need to roll on of course B)
FRANKEN Z!
