Brake cylinder question.
  • Goalieguy35
  • Goalieguy35's Avatar Topic Author
  • JJ
15 Nov 2011 01:15
#488533
Where can i get the inner runner for the cylinder on the handle bar? its off a 1980z1000. The assembly is fine just the rubber internal piece is junk. Thanks
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • MFolks
  • MFolks's Avatar
Re: Brake cylinder question.
15 Nov 2011 01:25
#488535
  • z1kzonly
  • z1kzonly's Avatar
15 Nov 2011 01:25
#488536
Please explain more.
Are you taking about the rubber trapezoid shaped diaprhagm? Under the cover?
Or the round piston in the bore?
Any picture?
  • Goalieguy35
  • JJ
15 Nov 2011 02:49
#488548
yes the runner trapezoid under the cover on the brake master cylinder.
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • Goalieguy35
  • JJ
15 Nov 2011 03:00
#488549
rubber*
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
15 Nov 2011 03:01 - 15 Nov 2011 03:09
#488550
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe rubber diaphragm 43028-1002 is shown as "limited availability" on kawasaki.com, so it might possibly be obtained through a Kawasaki dealership.
The rubber diaphragm isn't listed at ebay under 43028-1002.
Plate 43027-1002 (between the top cover and rubber diaphragm) is shown as "cancelled."
Searching 43028-1002 on ebay produces the following:
Good Fortune! :)
Last edit: 15 Nov 2011 03:09 by Patton.
  • Goalieguy35
  • JJ
15 Nov 2011 03:05
#488551
Thank you patton!
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
