Fork Disassembly & Assembly, special tools needed?
Re: Fork Disassembly & Assembly, special tools needed?
14 Nov 2011 23:15
#488519
RTGPZ wrote: I,m no pro and you'll find many different theory on front forks but to keep it simple . Use standard wt oil ,then raise oil level to create more stiffness when forks compress down.lower fork oil level to create a softer cushion feel . It seemed you had to much oil and to heavy a wt..The only way to adjust rebound is to open up valve inside forks,but i wood not play with it.
Not so. Lighter or heavier weight fork oil can be used to adjust both rebound and compression. (see pages from manual above where oil flow is explained). Ed
  • Breaker19
  • Breaker19's Avatar
22 Dec 2011 16:13
#494350
I have Progressive's and 10W in my Suzuki DR650 and it likewise rides much better than stock, but I think 10W is the OE weight for that bike. Heck, just changing the fork oil after the old stuff has been in there for a decade or more makes a big diff! :)
2003 Suzuki DR650 Dual-Sport
1982 KZ1100A2 - GONE! Traded-in for a '12 Concours 14
www.facebook.com/pages/Moto-Resto/169238286503527
  • RTGPZ
  • RTGPZ's Avatar
26 Nov 2012 20:09
#560147
Isn't that what i just wrote by changing fork oil wt and how much oil is in fork tube it will effect the ride. everybody s a critic, open the part of your brain that can reason with a problem not justify your cause!
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
  • 750steve
  • 750steve's Avatar Topic Author
26 Nov 2012 20:19
#560149
Oooooooooooooooo! Touchy!!!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
