Fork Disassembly & Assembly, special tools needed?
Re: Fork Disassembly & Assembly, special tools needed?
13 Nov 2011 19:10 - 14 Nov 2011 09:47
#488337
I didn't realize the bike was apart, but since it is, have you thought about replacing the steering stem bearings? The tapered roller bearings totally eliminate the notch behavior that worn, stock ball type bearings can have. That is one of the very few changes I've made to my stock bike, and I'm very happy with the results. It was a big improvement on my bike for tiny $$. Ed
Last edit: 14 Nov 2011 09:47 by 650ed.
  • 750steve
  • 750steve's Avatar Topic Author
13 Nov 2011 19:32 - 14 Nov 2011 04:52
#488340
No eBay APP ID and/or Cert ID defined in Kunena configurationOk, you must be some kind of a mind reader Ed! Even though mine feel ok I ordered these about the time you posted here last!
I just hope they're good quality
I'll prob do all 5 wheel bearings too when it's stripped that far
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 14 Nov 2011 04:52 by 750steve. Reason: spelling
  • 750steve
13 Nov 2011 21:48 - 13 Nov 2011 21:50
#488359
Looks like may have to use something other than Bel-Ray, $32 through eBay, $32 delivery too.
I dont know if you guys have Silkolene over there but it should be ok.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 13 Nov 2011 21:50 by 750steve.
  • wireman
  • wireman's Avatar
13 Nov 2011 22:00
#488364
i dont know about over filling and drilling holes in the dampners,i just fill to stock level with the 30w synthetic motor oil after measuring it in a metric measuring cup.
no need to use the tool to hold dampner if you have an air ratchet,same goes for reassembly.
definately go with the tapered steering head bearings. B)
13 Nov 2011 23:19
#488377
wireman wrote: i dont know about over filling and drilling holes in the dampners,i just fill to stock level with the 30w synthetic motor oil after measuring it in a metric measuring cup.
I don't recommend using an impact wrench to tighten the bolts because it is not possible to accurately measure the amount of torque being applied. I've seen too many truck wheel lugs wrung off using such a tool to tighten lug nuts, and they are tougher than fork bolts, so my view is why take that risk when it is so easy to simply make a tool to do the job safely? Using a tool to hold the fork cylinder while using a torque wrench to tighten the bolt is the only way I know to ensure the bolt is tightened to the correct torque. As far as the fluid to be used, I don't use fork oil in my motor or motor oil in my forks. :laugh: Ed
  • 750steve
14 Nov 2011 04:50
#488411
No eBay APP ID and/or Cert ID defined in Kunena configurationWell the silkolene seems to be slightly cheaper than the Bel-Ray Fork Oil (over here anyway)
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
14 Nov 2011 05:27 - 13 Feb 2012 17:50
#488413
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:50 by KZ250LTD.
14 Nov 2011 09:43 - 14 Nov 2011 09:55
#488426
KZ250LTD wrote: Not to bash belray but for the most part fork oil is fork oil, on a 35 year old bike I doubt you'll notice the difference between $35 fluid and $12 fluid...
I agree, that's why I always use Bel-Ray. It costs about $11.00. If your dealer is charging $35 it's time to find a better dealer. Ed
www.powersportsuperstore.com/Bel-Ray-Hig...4039.htm?Click=35177
Last edit: 14 Nov 2011 09:55 by 650ed.
14 Nov 2011 09:53
#488428
This may help clarify how the front forks control compression and rebound:
Attachment FORKPAGE1.jpg not found
Attachment FORKPAGE2.jpg not found
Attachment FORKPAGE3.jpg not found
  • steell
  • steell's Avatar
14 Nov 2011 21:21
#488504
I used 15W fork oil in my 79 750 twin and the front end was way to stiff. Rumble strips on the road would jar your teeth loose.
Switched to Progressive fork springs with 10w fork oil and it made an amazing improvement.
  • RTGPZ
  • RTGPZ's Avatar
14 Nov 2011 21:36
#488507
I,m no pro and you'll find many different theory on front forks but to keep it simple . Use standard wt oil ,then raise oil level to create more stiffness when forks compress down.lower fork oil level to create a softer cushion feel . It seemed you had to much oil and to heavy a wt..The only way to adjust rebound is to open up valve inside forks,but i wood not play with it.
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
  • 750steve
14 Nov 2011 23:08
#488518
steell wrote: Switched to Progressive fork springs with 10w fork oil and it made an amazing improvement.
Do you have any lying about in your parts dept Steve? :lol:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
